It is currently Tue Oct 20, 2026 6:36 pm
Post new topic Reply to topic  [ 100 posts ]  Go to page 1, 2, 3, 4  Next
Post Posted: Tue Mar 17, 2009 3:20 pm
Hello good people. I hate to ask these questions.. but im having troubles finding the answers!! For the record, I have searched this forum, and others, and have found tonnes of info.. but theres still a few things I’m unsure about!
I am about to buy a ?1998? 1.6 efi Vit motor, (actually also getting all of the running gear, tank, gauges, exhaust, comp, lume. Etc). The plan is to put it into my 1991 sierra. I have just ordered one of BenT adaptor kits too. The qtns..
1: Which sump AND pickup do I use?? (I am SPOA on lux diffs)
2: Exhaust.. Will the standard 1.6 manifold clear, or will I need extractors? Also, should I chop the exhaust that’s on the zook at the moment, and then join the 1.6 manifold/extractors onto the current exhaust?
3: When I get the vitara fuel tank and pump, will I be able to fit this into my sierra, re-run the lines (using high pressure lines).. and then the fuel system will then be taken care of?? Or will there be more I will have to do to it??
4: Do I continue to use the 1.6 clutch?? (I will be using the 1.3 gearbox)
Thanks lots!!!!
Post Posted: Tue Mar 17, 2009 3:29 pm
I can answer the first q :D
You need the G13 sump with a chop and weld combo of 1.3 and 1.6 oil pick up. You need the 1.3 pick up to match the sump but where it goes into the oil pump it is a smaller size, hence the 1.6 bit needs to be welded on. Does that make any sense? :?
I'm not 100% sure on the exhaust manifold but I think it fowls on the engine mount? Someone will correct me if I'm wrong.
Post Posted: Tue Mar 17, 2009 3:36 pm
1. If your spoa, even with lux diffs, you should be ok clearance wise. Otherwise. sierra sump. Sierra pickup, vitara pickup tube end.
2. I used custom extractors. They were offshelf vitara ones. Every brand is different. People have used jimny extractors also. Meant to come tighter around engine fo clearance of chassis/engine mount.
Few people have managed to use the vitara stock manifold. Just didnt work for me, outlet went into chassis. If you have it, try it.
3. Vitara efi tank and intank pump. Perfect. With a efi high pressure fuel filter.
4. Use 1.3 clutch.
1.3 flywheel.
1.6 starter(i have heard) I used a turned down on lathe 1.3 starter.
Post Posted: Tue Mar 17, 2009 4:30 pm
as bluesuzy said. though on all the conversions i have done i have never had a problem with the early manifold. the late model type 2 version does get close, but you have 1.3 engine mounts so it should sit ok. the type 2 manifold is also way better than most aftermarket systems.
Post Posted: Tue Mar 17, 2009 5:20 pm
Woo Hoo!! Thanks guys!!
So the plan will be:
1: Leave the 1.6 sump and pickup alone.. and hope that it doesn’t hit on full compression of the suspension??
2: Try the vitara 1.6 manifold, if it does hit, look into extractors or something??
3: Use the Vitara tank and pump (replace my sierra tank all together). I’ll upgrade to a high pressure filter.. will the fuel lines need upgrading too??
4: The 1.3 clutch is getting sad.. so might look into replacing that while the eng is out. Plus i'll use the 1.6 starter.
Thanks for the help peoples :D
Post Posted: Tue Mar 17, 2009 5:27 pm
Yes, New fuel hoses.
I use the existing fuel rail along the chassis also. Pressure and return. Piss easy to do.
Post Posted: Tue Mar 17, 2009 5:40 pm
Lovely work!! Thanks again..
Post Posted: Mon Mar 23, 2009 12:38 am
Well i've got the motor and stuff home!! Its a G16A, out of a 1996 Vitara. I've got the 1.3 out, and have swapped the clutch over etc.
Got a few more qtn's (sorry guys)
I have ordered BenT's adaptor kit, but i will still need to run the standard sierra eng mounts yeah??
I have been searching around for a wiring diagram.. found a link to a site which sounds like it would have one.. but keeps coming up that the server is busy os something.. does anyone know how i can get hold of a copy? (please!!)
And finally, a qtn to those who have done the wiring!! I love playing around with auto elec stuff.. but i have never tackled a job like this!!
What Would you recomend?? Should i pay an auto elec? (guessing this would cost HEAPS though), should i give it a go? hehe, this looks nice!! http://www.trailtough.com/index.php?pag ... &Itemid=53
So at the moment, the wiring is scaring the shit out of me.. and i havent even had a "mans look" at it!!! 8O thanks..
Post Posted: Mon Mar 23, 2009 3:24 am
you should send it too me, and for a small fee i will get rid of the crap and mark the wires that need to go to certain spots. and then i will send it back. :wink:
Post Posted: Mon Mar 23, 2009 11:10 am
pm sent joe!!
Post Posted: Mon Mar 23, 2009 1:09 pm
I thought the adaptor kit came with the modded engine mounts?
Wiring was a mess for me, i had the whole car harness and it all intertwines with fuse boxes and crap.(baleno had electric everything!)
I mainly worked out mine by a ect/ecu pinout with colours etc. So about 3/4 your wiring is, either re-use for extensions, or chuck in the bin!
Post Posted: Mon Mar 23, 2009 4:20 pm
i dont think so.. heres his link to the pic http://i101.photobucket.com/albums/m57/ ... torkit.jpg
My 1.3 mounts are busted.. and if i need to run 1.3 mounts, i need to get onto buying some ASAP!!!! hmmm.. that wiring still seems like a big issue then hey!! I've got onto a link which shows how to hook up the speed sensor.. that looks pretty straight forward..
Vehicle: '92 Sierra
Post Posted: Mon Mar 23, 2009 5:45 pm
Hey zooker. I've got that BenT kit. The black bit of what looks like modded rhs at the bottom is the engine mount adapter. It bolts to your driver side mount. The passenger one just bolts up.
Post Posted: Mon Mar 23, 2009 5:49 pm
thanks champ!! So i will need the 1.3 mounts then??
Post Posted: Tue Mar 24, 2009 3:22 pm
After doing "more" research.. i now that i have to attach approx 6 wires from the Vit lume, into 2 the lumes off the sierra. Can anyone please help me out with this!?!?!?! I still cant track down a wiring diagram either.. the ones from the download section on this forum dont work.. seems like the suzukiinfo site isnt working :cry: I have got the ENTIRE wiring off the whole vitara.. and most things are marked. To make life heaps easier, i would love to track someone down that is interested in sorting it out for me.. $$ is on offer!!! I have tried local auto elecs.. but their not interested. :cry:
Post Posted: Tue Mar 24, 2009 4:49 pm
It took me 3 months to do the conversion, 2 months of that was finding wires, and working out the baleno wiring hahaha.
Did you name each wire off the original 1.3?
If i was ever to do another suzuki motor again,
*I would put the whole harness on the motor
*Find the part that goes into the cabin. Cut whole harness there.
*Go to the ecu, then cut say 500mm from the ecu.
*Chase the colours for the engine harness and join. All wires should be different colours. Except for the earths.
Then there will be limited wires to join out of the ecu to the dash and Ignition, MainPower, Earth, Fuel pump, vss, Tacho etc etc.
I think the baleno diagram/pinout is different so i cant help you there.
I found another site, for google "vitara ecu pinout". If you take the top plate off the ecu. You may find names for the Ignition, MainPower, Earth, Fuel pump, vss, Tacho etc etc.
Im trying to help :D
Yes it is scary. But you have achieved heaps with ur zooky, Don't let this small wiring problem stop your ability! YES IT IS A SMALL JOB. Just you wait till you realise.
Vehicle: '92 Sierra
Post Posted: Tue Mar 24, 2009 5:05 pm
Hey Zooker, I think you can use the 1.3 or the 1.6 mounts. The ones on my 8 valve 1.6 were the same. Either way yes you will have to run engine mounts that are the same as the 1.3 stock mounts. I bought new ones off ebay for the missus car if I recall correctly.
As for the loom PM Joeblow on this forum. I seem to remember him offering to sort a loom out for someone for a fee. I think he was just talking about mailing it to him to sort.
Post Posted: Tue Mar 24, 2009 5:27 pm
Thanks heaps champ.. will go and search that now!!
Post Posted: Tue Mar 24, 2009 5:28 pm
I have PM'd him.. he didnt reply :( Hopefully he just hasnt been on and checked it for a couple of days!! Tar :)
Post Posted: Tue Mar 24, 2009 7:10 pm
will pm ya tonight...... :oops: ............sorry..been flat out........
Post Posted: Tue Mar 24, 2009 7:15 pm
Woo Hoo!!!! :D :D
Post Posted: Wed Mar 25, 2009 1:33 am
pm sent.............. :D
Post Posted: Fri Mar 27, 2009 11:50 pm
Well the 1.6 is ready to be lifted in!! I found out that the donor motor is actually out of a 1995.. so all the wiring diagrams i've sourced dont match!! So, im trying to find a wiring lume for a 1995, G16A, EFI 1.6 asap please!!
Does anyone have any idea where this broken fuel hose goes please??
And these 2 fuel hoses, im guessing the pretty one that has been crimped is the for the delivery, and the other is for the return??
Thanks plenty :D
Post Posted: Sat Mar 28, 2009 12:08 am
Thanks plenty :D
ummmm....for starters don't hook fuel up to that!....thats a coolant line for the idle-up actuator.
Vehicle: 75 Cruiser
Post Posted: Sat Mar 28, 2009 12:14 am
Yeah! It'll run backwards if ya do that !
Post Posted: Sat Mar 28, 2009 12:40 pm
8O hahaha, whoopsys :? So i'll hook that up to the the port thats next to where the radiator hose goes on?? You can see it in the other pic i put up...
Post Posted: Sat Mar 28, 2009 1:15 pm
i agree about the wireing scarey at first but once your done your like hey wtf i just did that and it was pretty easy. lol good luck man.
sam
Post Posted: Sat Mar 28, 2009 1:41 pm
Buhahaha its a good learning process. :mrgreen:
Post Posted: Mon Mar 30, 2009 3:34 pm
Hello again!!! Just wondering, can i remove the air flow sensor, and somehow install it into the sierra 1.3 airbox? The vit airbox is a huge piece of equipment.. and would be ever so nice if i could keep the sierras stock airbox!! Pics would be very handy to please :D
Post Posted: Sun Apr 05, 2009 12:46 pm
Another qtn please!! The G16A i'm running (out of a 1995 vit) is suppose to have its own coil, which has 2 plugs going to it. Is there any way i can use my old 1.3 coil to run the G16A?? I didnt get a coil with the motor, but i have plenty of standard type ones.. just wondering if theres a way i can run one of them?? Thanks again
Users browsing this forum: Google [Bot] and 209 guests
