https://auszookers.com/forum/
Sierra 1.6 conversion, 1st day cracked transfer case
https://auszookers.com/forum/viewtopic.php?f=5&t=43582
Author:  biff10 [ Fri Oct 25, 2013 8:31 pm ]
Post subject:  Sierra 1.6 conversion, 1st day cracked transfer case
Just had the g16b put in the my coily and whilst testing it out on day 1 i have cracked my transfer case (very big) across the input shaft housing area. (To dark to take photos)
Coily with wt transfer with 4:9:1 gears.
Has any body had/heard of this happening? Also i havnt pulled it out yet but do you think the gears would have survived?
Cheers in advance.
Author:  kenn [ Fri Oct 25, 2013 9:15 pm ]
Post subject:  Re: Sierra 1.6 conversion, 1st day cracked transfer case
I think the gears caused it. But that's just my opinion as I've seen this before on friends cars.
Author:  biff10 [ Fri Oct 25, 2013 9:59 pm ]
Cheers kenn, have the gears normally survived?
Author:  kenn [ Fri Oct 25, 2013 10:10 pm ]
Long enough to make it to the bin. The ones I've seen did a bit more than just crack the case so yours might be ok plus they were older versions, I think the new ones are made a bit better now. I still wouldn't run them unless someone wanted me to do a destruction test on them.
Author:  alien [ Sat Oct 26, 2013 12:47 am ]
i assume you fitted the WT Tcase without bracing the mounts? (Search Roctoy Ring on here)
Author:  got_bar_work [ Sat Oct 26, 2013 7:33 am ]
It was the old rockhopper gears that use to shit them self all the time
