It is currently Sat Oct 31, 2026 10:59 am
Vehicle: '97 Sierra
Post Posted: Fri Nov 01, 2013 12:22 pm
Hi, the bushes in my rear control arm have had it so need to get them replaced. I was hoping to do this myself, just wanted to check a couple of things. It's for a Coil Sierra.
1. Can I get some bushes that I can put in without having to press them in?
2. If so can anyone recommend a decent set for the rear?
3. How hard/easy is it to get the old bushes out of the control arms?
4. Is it 3 bushes on each arm that I need to replace?
Cheers.
Post Posted: Fri Nov 01, 2013 3:06 pm
Im pretty sure they need to be pressed in and out and yep 3 per arm
Post Posted: Fri Nov 01, 2013 3:12 pm
buy genuine/rubber bushes or 6 months down the track you'll be posting about the poly bushes tearing the control arm mounts off the diff housing.
Vehicle: '97 Sierra
Post Posted: Fri Nov 01, 2013 3:24 pm
Ok guys, thanks for the help. Yeah I figured I would need a press to do the job, which I don't have. Atari, where is the best place to get them from, do you know?
Post Posted: Fri Nov 01, 2013 3:27 pm
NFI i don't do sierra's, let alone coilys. :lol:
The part numbers for genuine rubber ones:
Bush where arm attaches to diff is SZ4628281A30 and bush where arm attaches to the chassis is SZ4621365D01
teh sirch: viewtopic.php?f=5&t=8983&p=126107&hilit=coily+bush+genuine#p126107
Vehicle: '97 Sierra
Post Posted: Fri Nov 01, 2013 3:34 pm
teh sirch: http://www.auszookers.com/forum/viewtop ... ne#p126107
Cheers, Appreciate it.
Vehicle: Coil Sierra
Post Posted: Sat Nov 02, 2013 9:39 pm
If you want to save some money you can push out the broken rubber and crush tube then hacksaw the outer case in two spots and knock them out. Then the shop only has to push the new ones in.
You can get some rubber ones on ebay through 4wd products.
Users browsing this forum: No registered users and 376 guests
