It is currently Sat Oct 31, 2026 10:59 am
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Nov 01, 2013 2:32 pm
Not sure what you call them but I want to get some new caps for the door lock mechanism. Currently using milkbar straws to stop them getting lost in the door panels, but that's a bit povo. I've been around SCA and Repco etc, but the caps they sell don't fit properly, both the normal ones and the novelty ones. Either the shaft bit is too thick or the novelty cap (skulls or dice) stop the mechanism from going up and down properly.
Any idea where I can source a zook approved replacement? Or any idea what thread size this is so I can figure out some sort of fix?
Online
Post Posted: Fri Nov 01, 2013 9:43 pm
I bought metal replacements in an Advance AutoParts in Florida, drilled them out and then cut them to size.
Vehicle: Suzuki Jimny 2013
Post Posted: Fri Nov 01, 2013 9:46 pm
I'm having similar issues with the cheap plastic ones being pulled off the thread.. I'm wondering if the Suzuki Chrome door fittings would be any better as they potentially screw onto the threat?
Post Posted: Fri Nov 01, 2013 10:11 pm
The thread is M5 0.7 (measured it with my tap/die set). I might check Suzistore tomorrow and see what they've got... probably the first place I should ask but only just occurred to me
Vehicle: SJ80, SE416
Post Posted: Fri Nov 01, 2013 10:38 pm
Wreckers or fellow Auszookers parting out a wreck...
Vehicle: 1992 sierra
Post Posted: Sat Nov 02, 2013 7:08 pm
You can have the ones off my car if you wish.
My sierra doesn't have a roof, so locking doors is a bit pointless.
Let me know if you are interested.
Post Posted: Sat Nov 02, 2013 7:22 pm
Suzistore sell genuine replacements... i think theyre $2ea?
Ninja edit:
http://suzistore.com.au/onlinestore/fou ... etail.html
$3.30ea.
Post Posted: Sat Nov 02, 2013 8:20 pm
alien wrote:
$3.30ea.
Too expensive for the average Sierra owner!
Post Posted: Sat Nov 02, 2013 11:57 pm
Yep, Suzistore had 'em. Got some earlier.
Post Posted: Sun Nov 03, 2013 1:13 am
last time I had to replace the lock doodads, I just used plastic wall plugs.
stephen
Users browsing this forum: No registered users and 377 guests
