https://auszookers.com/forum/
Need lower gearing?? Bigger Tires :D
https://auszookers.com/forum/viewtopic.php?f=5&t=43889
Author:  Rust [ Thu Nov 14, 2013 4:44 am ]
Post subject:  Need lower gearing?? Bigger Tires :D
Hi Guys :)
I have a GV1600 3Door with 5.12 diff's and and 30's... I Really want to ride on 31's or a 32's :)
I have 3" Bodylift and 2" springkit...
I myself am a panel beater, so space for the wheels is not a problem
But i really need lower gearing all over... now with 30" I think that it is too highly geared
Can I install another gearbox from the older Vit or something??
Author:  christover1 [ Thu Nov 14, 2013 7:25 am ]
Post subject:  Re: Need lower gearing?? Bigger Tires :D
Only buying option I am aware of to lower high range is diff gears.
5:72 available from Fourx4art in Europe.
Other options involving fabrication are fitting Sierra transfer case, instead of, or as well as the vit box.
Author:  got_bar_work [ Thu Nov 14, 2013 8:50 am ]
And having it hang way down
I just pulled the pin on the doubler after measuring it up and finding it will hang down like 80 mm
Screw that I will drive round in 3rd
Author:  christover1 [ Thu Nov 14, 2013 9:23 am ]
I'll probably go the 2.0L J20 using my 5:12's and steelie diff etc
Author:  klutched [ Thu Nov 14, 2013 10:16 am ]
I'm running 235/85R16 (31.8") in my LWB with 5.12s and it pushes them ok.
Get the 5.7s from fourx4art and then reduction gears :D
I think the 5.7s will put it pretty correct because the swb has 5.12s stock??? I am still about 90km/h on dash to 100km/h and that's going from 4.8's to 5.12s.
Author:  SierraDan [ Fri Nov 15, 2013 6:07 am ]
Cant clock the transfer?
