| front spring advice https://auszookers.com/forum/viewtopic.php?f=5&t=43900 |
| Author: | sur5a [ Thu Nov 14, 2013 7:12 pm ] |
| Post subject: | front spring advice |
Hi peoples ,i put some springs in the jimmy couple weeks ago and had a look today seem to have shifted abit at the bottom i think,first time doing this and wanted to know if they have to be right up against the edge of the bottom mount ledge thingy, any help or advice ? Not sure if it matters or not |
| Author: | Jezza86 [ Fri Nov 15, 2013 7:14 am ] |
| Post subject: | Re: front spring advice |
they will do that, and will get a bit noisy when flxing. its nothing to worry about they typically dont move much further then that. |
| Author: | Gwagensteve [ Fri Nov 15, 2013 7:22 am ] |
X2. Normal and nothing to worry about. |
| Author: | sur5a [ Fri Nov 15, 2013 7:42 am ] |
thanks guys |
| Author: | Gwagensteve [ Fri Nov 15, 2013 8:05 am ] |
It's probably happening because those aftermarket springs are slightly shorter than standard springs. Often, lift springs are a little bit shorter when out of the vehicle due to design parameters, and this will mean they can go a little bit loose on full flex, which will cause them to move around a bit. |
| Author: | sur5a [ Fri Nov 15, 2013 8:33 am ] |
Gwagensteve wrote: It's probably happening because those aftermarket springs are slightly shorter than standard springs. Often, lift springs are a little bit shorter when out of the vehicle due to design parameters, and this will mean they can go a little bit loose on full flex, which will cause them to move around a bit. thanks for the info ,heres pic of comparison to stock just for reference |
| Author: | Gwagensteve [ Fri Nov 15, 2013 8:47 am ] |
Bit hard to see, but it does look that the new springs are slightly shorter. Steve. |
