https://auszookers.com/forum/
problem fitting g16b
https://auszookers.com/forum/viewtopic.php?f=5&t=43910
Author:  zooky08 [ Fri Nov 15, 2013 4:54 pm ]
Post subject:  problem fitting g16b
Has any one came across this problem were g16b hits the brake hard lines coming out of the brake cylinder. Running a 2 body lift. Body still has to go towards passenger side 10mm.
Author:  want33s [ Fri Nov 15, 2013 5:02 pm ]
Post subject:  Re: problem fitting g16b
What engine mounts are you using? Commonwhore?
Author:  zooky08 [ Fri Nov 15, 2013 5:09 pm ]
Looks like stock on ps and benT on ds. Engine was pulled from another sierra
Author:  stockman [ Fri Nov 15, 2013 5:55 pm ]
I had to adjust the hardline when doing my g13bb conversion, but don't recall having to do it with my Baleno g16b conversion (slightly taller motor).
Author:  Rossco [ Fri Nov 15, 2013 6:48 pm ]
I have the same setup and mine doesn't hit. There is some trickery going on somewhere, I'll check mine out in the morning.
Author:  azzas15 [ Sat Nov 16, 2013 8:10 am ]
I have plenty of space on mine I'll check again when I get home
Author:  BenT [ Sat Nov 16, 2013 11:03 am ]
Check that the cast engine mount brackets that bolt to the block are from the 1300. The 1600 ones are a different height and might be causing the engine to lean over.
Ben
Author:  azzas15 [ Sun Nov 17, 2013 3:27 pm ]
Here is a pic of mine not sure why yours is so close
Author:  zooky08 [ Sun Nov 17, 2013 4:10 pm ]
Yours is from a baleno right? My g16b is from a vitara. Might be different. You running body lift at all?
Author:  azzas15 [ Mon Nov 18, 2013 8:26 am ]
Yes my G16b is from a Baleno
