It is currently Fri Oct 30, 2026 6:39 pm
Vehicle: Soon to be Sierra (hopefully)
Post Posted: Fri Nov 15, 2013 10:58 am
Due to some requests, I'm going to keep it all in one thread from now on so here we go!
Got it for $500 so im happy.
100,364km. Its due for its major service (last service was at 75,000km. Car turned on and sounded in good mechanical condition :)
Can I use the A/C system allready on this G16B into the sierra? i noticed the a/c panel is very similar to the vitara systems?? with the push buttons
Seller indicated the gearbox was rooted; its actually in good condition (clutch cable needed an adjustment).
Engine out time:
full wiring loom (Got a bit carried away :P )
Also took the front seats, air con system (and hardlines), seat belts and fuel tank out (for the pump)
Post Posted: Fri Nov 15, 2013 11:00 am
Now all I need is a nice SWB soft top sierra with a 2" body lift , some air lockers (wishful thinking), 92+ model would be ideal haha!
Here is a list of parts I am going to buy soon; if anyone knows better... please let me know
Trying to organise it all and the links dont work anymore on cairnszooks build thread... so its hard to tell
VL motor mounts (is it these ones?)
http://www.ebay.com.au/itm/Holden-VL-6c ... d2b&_uhb=1
clutch kit? is this the right one (exedy hd)
http://www.ebay.com.au/itm/H-DUTY-CLUTC ... 256b0938d0
swift 1.3L thermostat housing
http://www.suzistore.com.au/onlinestore ... etail.html
which thermostat?
swift 1.3L?
Baleno 1.6L?
Sierra 1.3L?
surely its the baleno thermo or doesn't it fit in the housing right?
timing belt kit (major 100k service)
http://www.ebay.com.au/itm/TIMING-BELT- ... 68a&_uhb=1 (on sale for the next 3 days)
Also chasing a coiley fuel tank
and a SWB soft top sierra :/
fibreglass canopy
Vehicle: 4wd
Post Posted: Fri Nov 15, 2013 12:19 pm
You suck at linking ebay.
Sierra mount will be fine, and stock exedy clutch will be fine. H/D is teh ghey for your application.
Watch out or you'll get sued.
Post Posted: Fri Nov 15, 2013 12:24 pm
ah thanks! updated the ebay links ha
Post Posted: Sat Nov 16, 2013 12:24 pm
The left and Centre pins don't need any modifying by the looks of it. Seems the right one does. ...
heres the left and centre one that goes to the engine
Here's the right one. I'm reading pj zooks diagram and it's bloody confusing
Vehicle: 89 Sierra Widetrack
Post Posted: Sat Nov 16, 2013 12:41 pm
I personally found it easier not to touch anything in the engine side of the loom here is mine when I finished itImage
I found it easier to start at the fuse box and start stripping back to the first plug all the stuff tuning to the rear is junk except for the fuel pump wire which should be pink
You will eventually start to understand the wiring diagram just take it slow if you cut something you can always re join it
Post Posted: Sat Nov 16, 2013 12:59 pm
Cheers man, il lstart form there until the wiring looks like this in that box
(far left) FI Main.
(next to FI) Fuel pump.
(bottom row) Thermo fan.
Blue 15A is FI fuse.
Yellow 20A is Dome fuse.
Vehicle: 4wd
Post Posted: Sat Nov 16, 2013 1:18 pm
Do you have a Sierra yet?
Post Posted: Sat Nov 16, 2013 1:21 pm
looking at one hopefully today/tomorrow... just getting the wiring side of the G16B done beforehand
Vehicle: 4wd
Post Posted: Sat Nov 16, 2013 1:30 pm
ah cool.
I got rid of thermo and from memory dome too.
Post Posted: Sun Nov 17, 2013 3:22 pm
that looks good to me. I left the thermo and just coiled it up in the bottom for future use if needed :)
Leave the dome it's needed just cannot remember what for I gave away my wiring diagram last week :(
Also if you have a look at the computer plug and work out what isn't required on the wiring diagram you can start to remove it from there also.
Post Posted: Tue Nov 19, 2013 5:04 pm
Still working on stripping loom :rambo:
this came in the mail today
Post Posted: Tue Nov 19, 2013 7:18 pm
can someone take a photo of were the thick pink wire (fuel pump in the relay box) goes to which plug, i accidently pulled it out of one of the plugs and cant figure which is which now!
Post Posted: Tue Nov 19, 2013 7:30 pm
Vehicle: SJ51T
Post Posted: Tue Nov 19, 2013 9:15 pm
think it goes straight to fuel pump, look on PJzooks guide
Post Posted: Wed Nov 20, 2013 6:33 am
it goes into either the grey or blue relay plug as the other end has a pin adapter... but i dont know which hole or plug
Post Posted: Wed Nov 20, 2013 6:42 am
I'll check when I get home tonight
Post Posted: Wed Nov 20, 2013 6:40 pm
Yeah your on the money Image
Post Posted: Wed Nov 20, 2013 6:51 pm
where does it go on the other end? :P thanks tho
Post Posted: Wed Nov 20, 2013 7:46 pm
Number 7 is the fuel pump relay. From there it runs straight to the fuel pump which is labeled as number 8.
So you can run it back through the plugs or just straight to the pump won't matter
Post Posted: Sat Nov 23, 2013 10:32 am
Users browsing this forum: Google [Bot] and 376 guests
