It is currently Thu Oct 29, 2026 9:41 pm
Vehicle: 92 model Sierra/Vitara 1.6Efi
Post Posted: Sun Nov 24, 2013 8:50 pm
Hi guys,
my Sierra steering box has that much play in it that the steering wheel moves nearly a quarter of a revolution before the play is taken up....no shit.
Has anybody here rebuilt one, or is buying a new one the better/cheaper option?
When driving any type of road these days, the front wheels get a wobble up like it just threw all the wheel weights at once, and it's getting worse. Do you think this is a result of nil pressure on the steering gear from too much play, or is it likely to be caused by something else?
I have jacked up the front end and it seems that wheel bearings and tie rod ends are good. U-bolts on the springs are tight, and shackles are fine also, though I could do with a set of rubber bushes.
Cheers,
Ted.
Post Posted: Sun Nov 24, 2013 9:35 pm
The wobbles will probably stem from your wheelbearings or king pins.
All Sierras have a ton of steering play. You'l probably find that new shackle bushes will help more than a steering box R&R. With live axles, leaf springs and no panhard bar you will always have the feeling that there's a ton of play (and/or vagueness) because the axle moves around under the car quite a bit.
You should be able to find someone who will rebuild the steering box but IIRC Suzistore sell them new for $200. If I was you I'd find the steering box from a low KMs Jimny and convert to power steering. :)
Post Posted: Sun Nov 24, 2013 10:45 pm
I think of the steering play as an "are you sure?" followed by a run up for the heavy bit where it starts working =)
Post Posted: Mon Nov 25, 2013 8:10 am
Thanks very much for that Sideways. Lots of useful info there so I can now check a couple of things. I will replace the rubbers, and check king pins and wheel bearings. Couldn't find any movement when the front end was off the ground yesterday though.
I might just get a new box though. I'm fair dinkum when I say the steering wheel turns nearly a quarter turn before the wheels move.
Thanks for your input too Alien. I'm not too sure I need the 'are you sure' before I commit where I drive. I need to commit and then just ride it out as there is often no turning back. I took my shorty up a hill yesterday morning that was so steep I had to back down as I couldn't keep the front wheels on the ground, and that was in low/low with 6.5's...haha.
Oh yeah,..Suzistore steering boxes are $395 plus postage. Where could I buy parts to rebuild?
Cheers,
Ted.
Vehicle: 98 Coily
Post Posted: Fri Feb 21, 2014 11:05 am
You get the steering play fixed? Did it end up being the steering box?
Post Posted: Fri Feb 21, 2014 11:22 am
you can adjust the play out of the boxes some times using the nut on top of the box.
Users browsing this forum: No registered users and 325 guests
