It is currently Thu Oct 29, 2026 5:21 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
Vehicle: suzuki, jimny 1998
Post Posted: Thu Nov 28, 2013 1:44 pm
hay guys I've got my self a 98 jimny and was after some ideas on what and how I can go about upgrading it, in order to make it an awesome off roader. I would like at least 2inch lift but am wondering what is involved with getting a 3inch lift. Oh and what is available to me in the way of engine upgrades e.g. info for engine swap to 1.6L and 1.8L.
Ps guys your opinion on what is over board or unwise is most welcome!!! :D
Post Posted: Thu Nov 28, 2013 7:13 pm
What do you habe locally to drive?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Nov 28, 2013 7:36 pm
the best thing you can do is drive it. its easy to see what you need first by just driving it
more aggressive tread can be good.
up here thers lots of mud, big deep bog holes. i have a bit over 150mm of extra height from tyres, body lift and suspension, but i havent found true need for lockers yet. others swear by lockers.
so go find something you cant drive, take pics, (we love pics!) and we will tr to figure out how you might be able to drive it, or what would make it easier.
Vehicle: Which one?
Post Posted: Thu Nov 28, 2013 7:39 pm
Speed holes.
Post Posted: Fri Nov 29, 2013 3:58 am
Dimpled speed holes
Post Posted: Fri Nov 29, 2013 9:21 pm
1.6L.
2" lift
235's
Gearing/Sierra case
Lockers
Upgrade axles/CVs
LED light bar
USB Stereo :P
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sat Nov 30, 2013 12:35 pm
Heres my stock reply
Before asking for mods, what terrain do you drive that you need the mods for?
Are you likely to hit a roo or do you need a winch because you like getting bogged by yourself? = bull bar
Cant get up bumpy hills? = locker
Cant get up slippery or loose surface hills? 2 lockers
Camping by yourself? = drawer system
Camping with hot french girlfriend? = roofrack
Need to talk to other people? Uhf
Boat, jetski? = trailer hitch
Old fella or kids? Trailer hitch, camper trailer
Jimny too slow? M15 or 16
Jimny way too fuckin slow? M18 or j20
Not enough tourqe? Gears.
Tires too small? 215s
Ruts too big? 235s
Rocks too big? 30s
Rocks in the ruts too big? 31s
Rutted bogholes with bumpy bits? 33s
Rocks bigger than the car? 35s
Tires dont fit in the guards? Trim guards
Still dont fit? Bumpstops
Still dont fit? Guard chop
Tires come off the wheels? Beadlocks
Sandy or dusty? ATs
Muddy? MTs
Wet? Snorkel.
Friend with sierra? Front recovery point
Friend with patrol? Rear recovery point
Dog? Seat covers
Cant see the rocks? Rock lights
Cant see the track? Light bar
Cant see the roos? Spotties
I would make this a bit better now, but im on my phone and just copying it was a pain.. lol
Post Posted: Sat Nov 30, 2013 12:53 pm
:rofl:
Post Posted: Sat Nov 30, 2013 12:58 pm
Oh and as far as overboard goes, the 3 inch lift is overboard.
Note that a lift is not mentioned in my list above at all, but a 40mm lift is probably as much as you want in a jimny, though a lot might dissagree, in most cases I belive a big lift is just for looks and poor handling.
My Jimny and my 1L sierra were both 215s with no lift and were perfect for what I was driving.
My twin locked ruf 1.3NT on 31s was lifted about 40mm, but was very diffent terrain and kept up with much bigger cars.
My current build is a bigger build, 50mm lift and 33x12.5s planning to drive through the jungle and up a volcano, then move back to Melbourne for some real 4x4ing..
Vehicle: hkbjk
Post Posted: Sun Dec 01, 2013 11:32 am
I agree with neo.
I came on here asking lots of questions about mods etc and got some excellent feedback on why I should do some and why I should not do others and so my build is always changing from what I originally had in mind. On top of that I do a mod then go and try it out to see how it handles and what difference it makes. Each time I cant do an obstacle off road I try to figure out whats stopping me, think of a mod that might help and ask lots of questions.
The best advice I received and applied was not to be concerned with lift. As was pointed out - suspension lift does not give you ore ground clearance on your lowest points - only bigger tyres will do that. To fit bigger tyres you can just trim out the guards and again as neo says if they rub, bump stops, if they still rub trim more and only if you really need to you could go for a body lift (I am running 31's on my 99 Jimny and I bought a 2 inch body lift and have not needed to install it to date.
I have found the rear ARB locker fantastic and makes a real difference when you cant get grip climbing either a loose or slippery hill (loose rocks or clay) and it has got me up things easily where before I was just spinning wheels.
I think approach and departure angle can be looked at improving through fabrication of your own bar work.
If you run on your own like I do and chances of getting stuck are moderate to high then a winch is the easiest method of self recover. Spend the money on a good one not a cheap 4500lb one as you should be aware the rating of pull is dependent on how many layers of rope are around the winch so the given rating is based on the first layer of rope - hence I went with a 9500lb runva winch which will still be pulling way ore then the weight of my car when all the layers are wound on.
Invest in some quality recovery gear.
A led light bar is great if you do alot of night driving and want a broad area lit up - also have a think about where you will mount it to avoid damage - I mounted mine on my bonnet so I can see it and navigate it away from the path of branches etc, it is quickly disconnected and put away when not needed via a waterproof quick disconnect plug.
On really steep hills I have found the gearing not to be optimal and I have strugged on a few so I have a sierra transfer case ready to go in as soon as I put some reduction gears in it I believe this will improve alot.
With all the mods so far y car still handles perfect on the road and is very capable off road.
Because of the larger tyres I have a set of JoeBlow custom axles ready to go in and also a rear full float kit which will mean that I only need to carry one set of spares for everything and also will mean easier track side repairs and servicing.
Post Posted: Sun Jan 05, 2014 2:55 pm
what is involved with getting a 1.6l engine in my jimny. Has anyone it, if s some pictures would be much appreciated!!! I would also like to know what is involved with getting a 1.8l as well.
Vehicle: WT sierra, GU CRD
Post Posted: Wed Jan 08, 2014 12:40 am
Adapter plate.
Someone smarter than me will add whether you change the computers over or anything like that.
:rofl:
Funny 'cause its true
Mr neo has given you such a comprehensive trouble shooting list, he deserves a beer.
I love ZD30. :)
Post Posted: Thu Jan 09, 2014 5:36 pm
Ok thanks :)
Post Posted: Thu Jan 09, 2014 5:50 pm
From the research that have already done I can get a 1.6L GV motor in with
out changing the cpu but i dont know whitch one :/
Post Posted: Thu Jan 09, 2014 5:51 pm
Jezza how do you post pics?
Post Posted: Fri Jan 10, 2014 6:00 am
There's only one 1.6 GV motor. However a coil pack Baleno motor will work just the same.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jan 10, 2014 7:17 am
like dis
(photobucket, insert the IMG tag into the reply/ post box
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Fri Jan 10, 2014 11:30 am
Check out my build thread! Ive put a 1.6 vitara bottom end in, bash plates to avoid smashing things and make it easier to slide over rocks, 215 at's. At the moment im building up my axles and basically rebuilding everything and plan for a snorkel and 2" lift
Post Posted: Sun Jan 12, 2014 6:28 am
Put a V6 in it. :)
Post Posted: Mon Jan 13, 2014 3:27 pm
I want it to be road legal
Post Posted: Mon Jan 13, 2014 3:36 pm
What size exhaust system would the best if im going to get
a 1.6 vitara engine conversion?
Post Posted: Mon Jan 13, 2014 4:44 pm
2"
Vehicle: Sj70 tintop
Post Posted: Mon Jan 13, 2014 5:46 pm
best mod to a jimny...
a lwb sierra or f55 scat.
end of story.
Post Posted: Mon Jan 13, 2014 9:00 pm
ok thanks
Post Posted: Mon Jan 13, 2014 10:01 pm
:roll:
Really?
I love ZD30. :)
Post Posted: Tue Jan 14, 2014 9:10 am
end of story.
Ha ha hardly
Vehicle: Jeep
Post Posted: Tue Jan 14, 2014 7:29 pm
You guys do realise this is " Suzuki Talk ", Not chat !
Less chat, more constructive replies guys... :roll:
Post Posted: Tue Jan 14, 2014 8:53 pm
Tell that to Jezza86 using chat for suzuki talk. :roll:
:thefinger:
In any case, OPs questions have been answered. I just found it humorous (after owning Joel's ultimate LWB sierra for a short period) that he now likes the sierras better again, after Jimny ownership.
I love ZD30. :)
Post Posted: Wed Jan 15, 2014 6:16 pm
oh crack daddy, you just want to be a real boy! :sup:
Vehicle: Jeep
Post Posted: Wed Jan 15, 2014 7:19 pm
You have been here long enough joel, to know the basic rules of AZ, Suzuki Talk is for constructive helpful replies, Not chat !
But if you havnt read the Moderation Guidelines lately, then here is a reminder -
Steve wrote:
Basicly, if you can't help or don't have anything positive to add, do not post.
Users browsing this forum: Google [Bot] and 548 guests
