It is currently Fri Oct 30, 2026 1:57 pm
Vehicle: Getting parts atm
Post Posted: Fri Nov 29, 2013 8:09 am
Hey guys,
I'm after some advice on what inline efi pump to run in my crawler running a g16b,
What brands are good etc, any advice would be great,
Parry
Vehicle: 85 ' Drover
Post Posted: Fri Nov 29, 2013 12:20 pm
You can either work out the maximum amount of fuel you can possibly use, based on injecotor size, then double it and buy a pump that suits that flow rate.
or just buy the same pump that comes in whatever car the g16b comes in from factory.
Post Posted: Fri Nov 29, 2013 1:02 pm
Just run the cheap, tried and proven VL commodore external high pressure EFI pump like many of us do. I'm just using a cheap derivative re:not bosch and it works fine.
Vehicle: X-90 + Lwb Sierra + DeVitt +++
Post Posted: Fri Nov 29, 2013 1:50 pm
^^ x2
Post Posted: Fri Nov 29, 2013 2:20 pm
Im fairly sure the VL pump is the 0 580 464 070.
http://www.bosch.com.au/car_parts/en/do ... lpumps.pdf
For interest sake, apparently the g16b injectors are 172cc/min, so 4 of them is about 41L/hour (at 100% duty, ie never). that 070 pump is rated at 130L/hour. You could get away with the 0 580 254 911 (95L/hour), i used one on my 4age for a few yrs. (4age injectors are 182 or so, not much difference)
There is no point pumping fuel around your car for no reason, just heats the fuel up.
Post Posted: Fri Nov 29, 2013 2:56 pm
Sweet, thanks for the info
Parry
Vehicle: 1995 soft top vitara
Post Posted: Fri Nov 29, 2013 4:02 pm
I also use the external vl pump, for a turbo application also. Perfect for the job, small and quiet also
Post Posted: Fri Nov 29, 2013 5:57 pm
except you can get the vl one cheaper and nearly every auto parts place in Australia has one sitting on the shelf
Post Posted: Sat Nov 30, 2013 9:59 am
This is the biggest factor. Its a very common pump. Think I got a new generic brand VL one for like $40 from ripco surprisingly.
Post Posted: Sat Nov 30, 2013 12:03 pm
yer well depends on price i guess.
I prefer the proper Bosch one which for the 070 is still $150ish on ebays.
I cant recall how much i paid for the 910, too long ago.
Users browsing this forum: No registered users and 402 guests
