Joined: Sun Feb 24, 2013 7:56 am Posts: 76 Location: Burnie, Tas
Vehicle: 95 Vitara Hardtop
Posted: Sun Dec 01, 2013 7:03 am
My manual says to disconnect earth from battery first, not sure why, up to you if you do this.
Mine is a 95 swb, dunno if there is any significant differences. Start by undoing the adjuster nut/s at the clutch release arm end, remove cable from all brackets/clamps between release arm and firewall, follow cable by hand if you can't see it all the way, undo 2 bolts holding cable to firewall, disconnect clutch cable hook from the clutch pedal,....and it should come out.
Users browsing this forum: No registered users and 391 guests
