It is currently Sat Oct 31, 2026 1:34 pm
Vehicle: V6 autolocker rear and so much
Post Posted: Mon Dec 02, 2013 7:41 pm
Has anyone ever ran the t-case reduction gears ? i'm considering getting some and am very curious as too what sort of top speed (kph) i will be able to reach in 4wdL.
Vehicle: 1985 LWB sierra
Post Posted: Mon Dec 02, 2013 7:43 pm
Need a bit more info then that.
-what car
-tyre size
-gears ratio you want
Jeremy
Post Posted: Mon Dec 02, 2013 8:13 pm
V6 Vitara I'm thinking.
Post Posted: Mon Dec 02, 2013 8:53 pm
Who cares how fast it goes in low range? That's what high range is for.
Post Posted: Tue Dec 03, 2013 8:44 am
Our Jeep will theoretically do 120KPH in low.
maybe he is thinking about racing it?
Post Posted: Tue Dec 03, 2013 10:00 am
I thought it was only patrol owners who boasted about how fast they could go in low range :D
Post Posted: Tue Dec 03, 2013 10:46 am
Its a jeep thing, catch me and i'll explain it to you :D
Post Posted: Tue Dec 03, 2013 12:00 pm
-what car
-tyre size
Jeremy
V6 Vitara
running 31x10.5
automatic
5.125 ratio
Post Posted: Tue Dec 03, 2013 12:03 pm
you try running at a sand dune in low with 134% reduction gears then your care, hence why i'm curious as to the top speed, these low gear's would be perfect for the mud but sand hummmm well lets just say momentum is every thing..
Post Posted: Tue Dec 03, 2013 12:58 pm
I do.
On the sand here I need low range, all of my Suzukis have needed to dip back down into first low for the softer stuff. Since I don't have the power to max out 4th low on sand I drive everywhere in low range. If I had crawler gears and a top speed of 20km/h in low it'd drive me nuts.
I'd say exactly that is why Sierras have such an abysmal crawl ratio, they were geared for sand.
Of course, that's really not an issue in a V6 Vit were you have more than enough power to pull high on pretty much any surface.
Post Posted: Tue Dec 03, 2013 1:27 pm
on 31s with 5.1 diff gears you will be doing 6000rpmish at 60 kpm
Post Posted: Tue Dec 03, 2013 2:53 pm
May i ask how you worked these figurers out ???
Post Posted: Tue Dec 03, 2013 3:05 pm
I don't have access to my gearing calculator ATM but that's looks right to me, except you'll need to unplug the low range light switch on the transfer to get 4th low. Otherwise you'll be at about 40km/h @ 6k.
Crawler gears are for crawling. That's why I said how fast you can go in low range isn't relevant if you want to run them.
Post Posted: Tue Dec 03, 2013 3:13 pm
I have a spreadsheet that i put figures into and it tells me things.
I could explain, but it would all be just numbers on a page.
Post Posted: Tue Dec 03, 2013 5:24 pm
No drama's, spread sheets say no more. soo i assume this is with 4 gear in low 4wd as steve has mentioned ? cause i get that sort of speed at the moment in 4wd low but thats in 3rd as 4th gear or overdrive is cut out in 4wd low on the automatic's
Post Posted: Tue Dec 03, 2013 5:27 pm
Unplug the low range light switch to the transfer case, tell me more about this please mate. any con's when doing this ? an extre gear in low would rock my world 8O
Post Posted: Tue Dec 03, 2013 6:04 pm
I disconnected the low range light on my Vit with crawler gears, so I could get OD (overdrive or 4th).
It is locked out normally in low.
Was almost undriveable before.
Vehicle: SJ51T
Post Posted: Tue Dec 03, 2013 7:28 pm
I drive sand in 1st high
Post Posted: Tue Dec 03, 2013 7:51 pm
Where about do i unplug this low range light from ?
Vehicle: WT sierra, GU CRD
Post Posted: Tue Dec 03, 2013 7:59 pm
Same, although the beastly but heroic 1.3 struggles sometimes.
I love ZD30. :)
Post Posted: Tue Dec 03, 2013 8:14 pm
I unplugged mine at the switch near the transfer case stick.
I imagine there is other options.
Having OD makes sand much easier.
Post Posted: Tue Dec 03, 2013 9:53 pm
On the transfer case. Just unplug it.
Post Posted: Wed Dec 04, 2013 4:07 am
Post Posted: Wed Dec 04, 2013 8:49 am
Bugger scrape this idea,
Calmini just emailed me saying "Our transfer case reduction is not applicable on your model vehicle."
Time for the h27 swap :evil:
Post Posted: Wed Dec 04, 2013 9:04 am
pretty sure thats incorrect.
Post Posted: Wed Dec 04, 2013 9:17 am
I'm sure they can fit too, i dont know how much difference there is in the transfer case between the 1600 an V6, But i'm not paying out the fund's nor start striping my case out until i know someone else has done it in a V6 vitara.
For roughly the same price i can do the h27 swap, with the pice of mind that it works.. 60 more horse's may help spin my wheels in the muddy tracks
Post Posted: Wed Dec 04, 2013 9:44 am
you can just pick up a 1.6 transfer case i believe and fit it to that.
Post Posted: Wed Dec 04, 2013 3:12 pm
Isnt it just a spline difference?
Post Posted: Wed Dec 04, 2013 3:19 pm
i think there is also a small length difference in the case
Post Posted: Wed Dec 04, 2013 5:08 pm
I thought V6 auto was the same spline as 1.6, it was V6 manual that was different.
In fact, I'm 100% sure CJ swapped the same crawler geared transfer from a 1.6 carby manual to a 1.6 EFI auto to a H20 V6 Auto and then to a J20 Auto. I helped with these swaps so I'm almost 100% positive.
Users browsing this forum: Google [Bot] and 321 guests
