It is currently Sun Oct 18, 2026 9:04 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Post Posted: Fri Mar 27, 2009 12:28 am
has anybody on here done a jimny engine conversion into a sierra? im guessing the block would be similar to the stock carby motor, so it might/could be a bolt in job?? i know the vit 1.6 has more power but i more or less just want injection. any info would be great, thanks
Post Posted: Fri Mar 27, 2009 12:50 am
i think sam did pm him
cheers scott
black coily, 30 inch tyers, 2 inch suspention, 2 i
Post Posted: Fri Mar 27, 2009 2:29 am
keep your standard engine mounts, you unbolt the engine mounts from your old block and bolt them to the g13bb.
you use a jimny top rad hose and one of the jimny heater hoses
use a sierra bottom hose and one of the sierra heater hoses
use jimny brake booster vacuum hose
bolts to the gearbox and they use the same clutch.
need to do wireing and plumb the airbox... DONE
i used a jimny accelorator cable and modded the pedal end
computer fits behind glovebox
i think it is a pretty big gain they rev harder than a g16b with standard exhausts manifolds they just don't have the torque. I have a freind with a g16b vit and i leave it behind up untill like 3rd gear after that it eats me. For me the improvement was well worth it. Even the fact that it starts straight away every time and sounds nice and runs smooth and would stay alive even upside down. I also like how they have coil packs instead of distrubutors, and i also like how they don't have the seperate air flow metres like g16b's do
jimny air hose, to sierra air box, peice of joiner in there.
Post Posted: Fri Mar 27, 2009 11:49 am
so how do they rev harder than a g16b? both engines have thier rev limiters at the same point. airflow meters are a better system for efi rather than map sensors, but they both work well. the only problem i have with g13bb's is that i threw a few away due to engine problems, not only myself but local suzi dealers too, and they are starting to pull a good dollar because of said problems. i ended up doing a g16 conversion in my jimny..........ahh..........all my unreliabilaty went away.
Post Posted: Fri Mar 27, 2009 11:54 am
JOEBLOW SAYS JIMNY HEAD BOLTS STRAIGHT ONTO 1.6LTR VIT . THAT WOULD BE GOOD CONVERSION FOR YOU.
Post Posted: Fri Mar 27, 2009 5:22 pm
Fair enough, i just mean they seem to rev out a bit quicker not the point they rev to, sorry. whats sort of issues where you having ?. and i was talking i don't like the airflow meter purely just because of where it has to sit not about how it works or anything.
i just did it because the conversion was easy, i would be interested to find out what issues you where having if this motor dies i will set fire to the sierra.
sam
Post Posted: Fri Mar 27, 2009 7:22 pm
sam
The 1.3 might rev a little quicker due to it's shorter stroke. The reciprocating components are most likely a little lighter as well.
Post Posted: Fri Mar 27, 2009 7:41 pm
thanks saam, i put a deposit on an engine today so ill be sure to get those hoses. all i want from it is a good cold start and reliability.
Post Posted: Fri Mar 27, 2009 9:14 pm
no worries mate, i am really happy with mine, i would like to know what joeblow had go wrong with his but hey i guess it's like anything.
sam
Post Posted: Fri Mar 27, 2009 10:14 pm
so its basically a straight bolt in swap nearly? how much more kw/hp dose the g13bb put out compared to the standard sierra engine?
cheers scott
Post Posted: Fri Mar 27, 2009 10:23 pm
58 kw at the motor as apposed to a standard coily motor which is 47 kw
i have sales brochures here lol.
Post Posted: Sat Mar 28, 2009 11:21 am
Stoopid question. Don't spose you have the torque specs differance.
Post Posted: Sat Mar 28, 2009 1:11 pm
100nm for 13ba (coily motor)
103nm for g13bb so sweet fuck all difference in torque
Post Posted: Sat Mar 28, 2009 2:53 pm
how about a M13A?
just wondering because my jimny has one.
someone said they are more reliable but i guess someone saying that doesn't mean much really
i know they have a bigger bore and shorter stroke. also is dohc, twin cam.
but what else if different?
Post Posted: Sat Mar 28, 2009 3:43 pm
it would be harder to fit. the reason people would go the G13bb is that they are still a G13 engine and therefore drop straight in, i was looking for info on the M13A to see if anyone had done a conversion but couldnt find anything
Post Posted: Sat Mar 28, 2009 4:47 pm
M13a also has some fancy inbuilt antitheft stuff going on too which makes wiring it into a sierra a right pain in the ass
Post Posted: Sat Mar 28, 2009 9:09 pm
m13a's are so horrible you pretty much need an entire m13a jimny to take the ignition switch coded key door switches and all sorts out of. It all seems to be intermangled
Post Posted: Sat Mar 28, 2009 10:17 pm
haha i see
Post Posted: Sun Mar 29, 2009 1:27 am
ok. another stoopid question. What is an m13a?? Is it standard in a later model Jimny?? and how do they go??
Post Posted: Sun Mar 29, 2009 1:39 am
the m13a was the motor that replaced the g13bb after it became a problematic motor
Post Posted: Sun Mar 29, 2009 3:17 pm
or more likely because they had brought the m series engines in the whole range of Suzuki that had previously had g series engines so they put one in the updated jimny aswell.
M13A is a twin cam mulitpoint injected 1.3, they also have a vvt version aswell.
Post Posted: Sun Mar 29, 2009 9:41 pm
So, do they go alright???
Post Posted: Mon Mar 30, 2009 12:51 am
yeah they are great motors just hard to convert into sierras
Post Posted: Mon Mar 30, 2009 1:03 am
but can they be bolted straight in or not if its just the wiring thats the problem you could just use a after market computer couldn't you?
 Profile YIM
Post Posted: Mon Mar 30, 2009 1:08 am
there needs to adapters and stuff but no they don't bolt straight in. you could use an aftermarket computer but it would be a complete engine rewire
Post Posted: Mon Mar 30, 2009 5:45 pm
G series all the way, I have a g13bb in my carry and its a beast super reliable and a friend has one thats done over 330,000klms without missing a beat.
I would stick with the G series, the g13bb is used extensively now on light aircraft thanks to its reputation. They have g13b style rods and the sohc 16v head is the same as the vitara 16v.
Post Posted: Mon Mar 30, 2009 8:29 pm
now thats the shit i like to hear! :D
Post Posted: Tue Mar 31, 2009 12:06 am
haha yeah putting in a m13a sounds like it would be a pain in the arse!
i would stick with the G series. unless you really think its worth it
Post Posted: Tue Mar 31, 2009 12:14 am
The m13a is a much better engine than the g13bb, but would be a lot harder to fit to a Sierra.
Im not a fan at all of the g13bb engine, but a 16valve efi engine upgrade for a Sierra doesnt get much easier and they are a big improvement over the standard engine, although they are pretty expensive last time i checked.
Id go 1.6, but hey,thats just me!
Users browsing this forum: Google [Bot], ProteinDrinker and 332 guests
