It is currently Thu Oct 29, 2026 9:03 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Sat Dec 28, 2013 12:11 pm
I need to make a cam and a follower piece to mechanise my Aisin carby. A pair of tiny little parts - looking to get them cut out of 7 or 8mm stainless. A pic below gives the basic idea.
Just wondering if anyone knows what it'd cost to get something like this CNC cut? Both of these pieces would fit on a 50x30mm piece of plate. I'm guessing it'd take maybe an hour to mock up in a CNC program, and a few minutes to cut from there.
Post Posted: Sat Dec 28, 2013 3:56 pm
$15...
Post Posted: Mon Dec 30, 2013 10:50 am
$15 would be awesome! Too bad nowhere is open to get a quote... bloody holidays.
Post Posted: Mon Dec 30, 2013 10:53 am
you could always try to get handy with a grinder? =)
Another option, make a mould and cast the parts out of resin to get you by until you can get metal ones made?
Post Posted: Mon Dec 30, 2013 10:54 am
I was thinking about it, but the drilled holes need to be perfectly square. I'd need a drill press to pull that off.
I wouldn't mind swing past a CNC shop and seeing what they charge, seeing what they do, etc. If they charge like the light brigade it might inspire me to get my own hobby CNC router for projects like this (which are always popping up).
Post Posted: Mon Dec 30, 2013 10:55 am
ninja edit while you were typing - see above..
Post Posted: Mon Dec 30, 2013 11:06 am
Lol - double edit bust :)
I'll wait for the CNC quote. They're simple little pieces but accuracy is critical. I've got a 100% accurate/scaled pic to use now, and all measurements have been taken... I wonder if they can just scan it in rather than mock it up themselves?
Post Posted: Mon Dec 30, 2013 12:07 pm
ask Pubic?
I am sure there is some kind of image format that can be converted easy enough
Vehicle: 85 ' Drover
Post Posted: Mon Dec 30, 2013 12:13 pm
If you can get it into .dxf format that will make life easier for the operator and a Cnc company will be more willing to do such a small job if you can give them the drawing in a file they can use.
Post Posted: Mon Dec 30, 2013 12:33 pm
PM me with whatever files you have and I will CAD it for you if its easy enough.
Post Posted: Mon Dec 30, 2013 6:38 pm
Thanks for the help Pyrohamish. I didn't realise this needed to be drawn up in a CAD program first. For some reason I thought the parts were drawn up in programs like Mach 3 BobCAD or Shark, but an a-ha moment I realise this software only controls g-code.
This is something I want to learn so I might have a crack at myself first - i'll get in touch if I give up and crack the shits! I've just downloaded Draftsight so hopefully I can get my head CAD.
Post Posted: Mon Dec 30, 2013 6:53 pm
Che, you can use Adobe Illustrator (free 30 day trial on the website) and draw it using the pen tool / circles etc, then export a DXF or DWG file. That's probably the most straightforward method, and there's tons of tutorials on drawing in illustrator (or you can come over my house and i can show you how to do it).
Post Posted: Mon Dec 30, 2013 9:10 pm
Done.
Draftsight seems super intuitive to use. Now to work out what type of DXF to save as - there's about 15 different options in the menu. I'll wait til I know what the CNCer wants I guess.
Post Posted: Mon Dec 30, 2013 11:10 pm
just save to the earliest version... the newer ones always open the older ones and not vice versa.
Users browsing this forum: winchzook and 293 guests
