It is currently Thu Oct 29, 2026 3:14 pm
Vehicle: Suzuki Jimny
Post Posted: Sat Jan 04, 2014 10:07 pm
Yes I have a problem with my Automatic locking hubs on my Jimny... As far as I could find is they seem to work fine if I unplug the lower vacuum hose on the fire wall they engage and dis engage very strong. but when I plug that lower hose in they will only dis engage. its got me very stumped ive pulled the hubs off and cleaned them and i don't have a flashing light on the dash or anything. its a leaver not button type Jimny.
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Jan 05, 2014 7:14 am
Have you pulled the hubs off recently? (Eg. Just before this started)
Post Posted: Sun Jan 05, 2014 9:54 am
Its hard to say I think it did it before i replaced the swivel hub/ axle seals.
Post Posted: Sun Jan 05, 2014 11:51 am
It's quite common to happen after you've had the hubs off... If you undo the bolts on the hub and take it off... Hold it close and get someone to activate 4WD for you and it should suck it on. Sounds weird I know, but this fixed it for me trackside once.
Post Posted: Sun Jan 05, 2014 1:00 pm
^beat me to it lol seems to shock it into working.
Post Posted: Sun Jan 05, 2014 9:14 pm
Give that a crack now i guess... but every thing seems to be in working order...
Post Posted: Mon Jan 06, 2014 1:49 pm
Sounds to me to be the only reason they aren't working. Everything else would give a flashing light. Had me and josh stumped until we started trying different things while we were out wheeling. I then found a post on bigjimny.com that confirmed it to be a common fault when replacing hub seals etc. I can't find that post now, tried looking yesterday, but there's so many different posts about the auto hubs failing that it makes searching a nightmare.
Have you looked into fitting a manual hub?
Post Posted: Mon Jan 06, 2014 2:30 pm
Yeh going down that path atm. Seems to be to many issue with these auto things... the only thing that puzzles me is they work fine when i take 1 hose off the vacuum lines on the fire wall... I thought 1 was locking and 1 was unlocking.
Post Posted: Mon Jan 06, 2014 2:33 pm
Have you taken the hubs off yet like we suggested? Not having a dig at you, just trying to eliminate it.
Post Posted: Mon Jan 06, 2014 2:37 pm
Yeh, several times both sides.
Post Posted: Mon Jan 06, 2014 2:41 pm
Sounds like one of the lines could be blocked... Can you unattached the rubber hoses from the engine bay and under the front right hand side and blow compressed air through them? Probly wouldn't hurt taking the hubs off and doing the same with the nozzles on them too...
Post Posted: Mon Jan 06, 2014 10:51 pm
So ive been right through them. cleaned the hubs replaced the lines there flowing well, took the filter off, everything seems to be working the even clicking now when i put it in 4WD. they just dont lock. wasted a good 4 hours going through the whole thing... FUCK THEM OFF.
WHO SELLS HUB RINGS FOR MANUAL HUBS IN AUSTRALIA???
Post Posted: Tue Jan 07, 2014 1:07 am
Did you put the filter on the right way round? It's a oneway valve so if it's on the wrong way it won't work.
Pm 31zook, he may have a set of rings, but I suggest cutting the end of the axle. We've both done this due to snapping hub bolts over and over again. This is with a front locker, chromos and 30" tires.... Standard cvs will bust before the hub bolts if you're running spacers, but there's another option for you to think about.
Post Posted: Tue Jan 07, 2014 4:50 am
Are the lines on the same way either side? Causing it to unlock on and lock the other? I will have a set of hubs up forsale shortly and I can supply the ring if needed.
Post Posted: Tue Jan 07, 2014 8:49 pm
if buy filter you mean the vacuum canister, yeah Its the same way it was.
Post Posted: Tue Jan 07, 2014 9:54 pm
Yeah sorry filter probly wasn't the best description. I think from memory it's whitish with a black top? I can get pics in the morning if you want to double check
Users browsing this forum: Google [Bot] and 276 guests
