https://auszookers.com/forum/
Suzuki Jimny issues, Car has been sitting for years, REBUILD
https://auszookers.com/forum/viewtopic.php?f=5&t=44602
Author:  Alexplicit [ Thu Jan 09, 2014 2:22 pm ]
Post subject:  Suzuki Jimny issues, Car has been sitting for years, REBUILD
hey guys
some of you may know me already, i had recently bought a suzuki sierra but the car was stolen only hours after purchase...
got this pretty cheap and it does need some work but i like a challenge and it keeps me busy!!
so far ive done the timing belt, and front crank case seals as it was leaking out quicker then i was putting oil in, has a bit of top end noise but thats nothing but an adjustment!!
so the issues i have are
brake lights not working, its not the bulbs and its not the brake light switch
Reverse lights not working, COULD BE THE REVERSE LIGHT SWITCH
blinkers arnt working, however, if i put the hazards on the front blinkers flash as they should but nothing at the back at all...
this will be constantly updated!!
thanks Alex
Author:  mrw82 [ Thu Jan 09, 2014 3:50 pm ]
Post subject:  Re: Suzuki Jimny issues, Car has been sitting for years, REB
The common link to all those lighting issues is the earth connection.
Author:  Alexplicit [ Thu Jan 09, 2014 9:43 pm ]
yep sorted this all out today!!!
was dirty connection at the rear lights coupled with a few dodgy fuses, reverse light switch was also bust, but took my reverse light switch from my rolled vitara
a few other issues brought themselves to my attention, im doing a Hilux/commodore shock swap, and went to do the fronts, both shock mounts on the diff have been broken, one completely gone, the other some shitty weld in place... is this a common issue?
Author:  Sookie [ Thu Jan 09, 2014 10:07 pm ]
viewtopic.php?f=5&t=28780
might be of some help you to
Author:  Alexplicit [ Fri Jan 10, 2014 5:55 am ]
ill keep note of that when i get around to the rear shocks, mine are on the front.. ill try get some photos
