https://auszookers.com/forum/
G13bb jimny input shaft
https://auszookers.com/forum/viewtopic.php?f=5&t=44613
Author:  cal213 [ Fri Jan 10, 2014 8:27 am ]
Post subject:  G13bb jimny input shaft
Where can i get a replacement input for the g13bb gearbox. Im going to assume the only place is suzuki or a custom machined one. Where the spigot bearing sits on the tip has worn down a groove
Author:  Gwagensteve [ Fri Jan 10, 2014 8:33 am ]
Post subject:  Re: G13bb jimny input shaft
Get it sleeved or welded? Otherwise you'll be looking for a whole second hand gearbox.
Author:  cal213 [ Fri Jan 10, 2014 11:22 am ]
That was the second idea, weld er up and machine it down at work. I have two gearboxes and rebuilding one now, i cant remember if my other box was the same in regards to the input. Im pretty sure it was. Ill get a pic
Author:  cal213 [ Fri Jan 10, 2014 4:13 pm ]
is this how it should look? i think the one in the car now looks the same after doing the clutch. it looks like its suppose to be, but after seeing an m13a one, i feel this could be wrong
Author:  Gwagensteve [ Fri Jan 10, 2014 5:25 pm ]
I vote that's how it's supposed to look . The spigot bearing will ride on the end just fine.
