It is currently Fri Oct 30, 2026 10:40 am
Vehicle: Sierra
Post Posted: Wed Jan 08, 2014 4:02 pm
what would you all advise as a most bang for your buck set of reduction gears for a 1989 suzuki sierra with 30" tyres that is used as a daily driver and future beginner offroading?
thanks, Jake
Post Posted: Wed Jan 08, 2014 4:11 pm
Probably 4.9:1
Depends on how steep your local terrain is though. If it's not super steep you could run 4.1
Vehicle: Sierra
Post Posted: Wed Jan 08, 2014 4:18 pm
Any brands that are tried and true, and good for money that i should look at?
Vehicle: sj51
Post Posted: Wed Jan 08, 2014 6:08 pm
i run 30's with trail gear 4.9:1 gears, they are great.
i got them from low range off road
Vehicle: '94 suzuki maruti
Post Posted: Wed Jan 08, 2014 9:48 pm
Probably 4.9:1
on lowrangeoffroad, thats the most expensive ratio, even moreso than the 6.5's. its the set i wanted, but settled for the 4.1's since they were nearly $200 cheaper.
or, it was when i bought the gears.
Post Posted: Fri Jan 10, 2014 11:41 pm
whincup wrote:
Probably 4.9:1
Current prices from Low Range Offroad site (in US $):
4.16 = $399
4.9 = $525
5.14 = $629
6.5 = $599
Vehicle: suzuki, jimny 1998
Post Posted: Mon Jan 13, 2014 3:32 pm
What about for a jimny that is going to have 3 to 4inch lift
with 30" a/t's?
Post Posted: Mon Jan 13, 2014 3:43 pm
^none of those gear fit without a sierra Tcase swap...
$1200 for gears in a jimny case
Post Posted: Tue Jan 14, 2014 11:45 am
Where can I get them, name and size if you know.
would like to explore both options.
Post Posted: Tue Jan 14, 2014 11:56 am
think the company is called trial jimny.
Post Posted: Tue Jan 14, 2014 12:56 pm
Trial jimny do the 24% chain swap- low and high both drop 24%
Apio do a replacement planetary that drops low range only.
Combining both is über awesome, but makes your transfer case worth one million dollars.
Users browsing this forum: Google [Bot] and 336 guests
