https://auszookers.com/forum/
94 EFI surging
https://auszookers.com/forum/viewtopic.php?f=5&t=44806
Author:  xl76 [ Thu Jan 23, 2014 12:38 pm ]
Post subject:  94 EFI surging
Hey everyone
I have a 94 B16 vit which has recently started to surge and miss around 2800 -3000 rpm on acceleration and then it will accelerate above that OK . I have checked the usual things
Air cleaner
spark plugs
compression
leads
new rotor and dizzy cap
Cleaned MAF
Cleaned throttle body
has anybody had this before out of the blue.
all help greatfull
Author:  jimny_timmy [ Thu Jan 23, 2014 2:41 pm ]
Post subject:  Re: 94 EFI surging
Auto or manual buddy?
Author:  xl76 [ Thu Jan 23, 2014 4:26 pm ]
Yeh Sorry Manual
Author:  xl76 [ Thu Jan 23, 2014 6:15 pm ]
just checked the ECU only code was 12
Author:  johnmath [ Thu Jan 23, 2014 10:38 pm ]
Diagnostic Code 12: Diagnostic Item: No fault or fault in not monitored circuit. http://www.rhinopower.org/diag/cel.html
Engines need three things: compression, fuel & spark. My guess would be a loose low tension ignition wire, or some other loose electrical wire (most likely on the engine) that is resonating or vibrating and making poor connection at the rpms where you have the surging. Good luck!
Author:  JrZook [ Fri Jan 24, 2014 10:48 am ]
Whats the fuel pressure like?
Author:  xl76 [ Sat Jan 25, 2014 1:11 pm ]
still no good
I have checked the wiring , cleaned every plug I can find compression 4 x 145psi I will check the fuel pressure
any Idea what is correct pressure is.
Author:  xl76 [ Sun Jan 26, 2014 5:50 pm ]
I think I have a answer , I was researching Outers and someone had a similar issue which sounded the same . Problem was the temp sensor
I disconnected mine and Bingo problem gone . Need a new Temp sensor
Author:  Scrawny [ Sun Jan 26, 2014 7:55 pm ]
Which temp sender?
Author:  xl76 [ Sun Jan 26, 2014 9:00 pm ]
There is one with a two wire plug on it left side bottom with a large plug
Author:  Rhinoman [ Mon Jan 27, 2014 5:15 am ]
I would advise that you check all the vacuum lines, surging is often caused by a leak which causes the ECU to be unable to properly control idle. It would also be worth cleaning out the EGR just in case thats sticking.
