It is currently Wed Oct 28, 2026 11:52 pm
Vehicle: Jimny
Post Posted: Fri Jan 24, 2014 8:02 am
hey guys, just out or curiosity what sorta economy are people getting with there Jimnys
running 235s, 30s, ect
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jan 24, 2014 8:40 am
30*9.5 km2's with a 27% gear reduction to get 4150rpm@ 100kph, tyre presure 32psi, geting 370k from 40l with a m13A vvt
10.8l/100
9.25km/l
usage practically doubles in soft sand
Vehicle: Jimny
Post Posted: Fri Jan 24, 2014 8:44 am
jesus thats vterrific i though it would be a dramatic down fall in economy.
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Jan 24, 2014 8:51 am
Fully loaded I was doin 14.5l sitting on 110
Vehicle: Jimny
Post Posted: Fri Jan 24, 2014 8:56 am
you guys find the 1.3 still pushes it along no worries with the bigger tyre, obviously with reduction gearing.
Post Posted: Fri Jan 24, 2014 9:19 am
Yeah it does the job just fine... Although everyone loves more power deep down inside
Vehicle: Jimny
Post Posted: Fri Jan 24, 2014 9:25 am
ah righto, i only wanna run 235s anyway
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jan 24, 2014 9:29 am
speak for yourself lol
i must be a gutter minded individual
the m13 is overworked and is slightly labored in a slight headwind in 5th with 30's
so if your nit immediately down changing to 4th (or just driving in 4th all the time to begin with) you can expect 14l/100, especially if your ruining tire pressures lower so your spine doesn't shatter.
i would not want to do many k's (especially on the roads here) with 32 pound in the tyres.
Post Posted: Fri Jan 24, 2014 9:36 am
I mean more power in the shape of an m15 or 18 mate ;)
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Fri Jan 24, 2014 10:12 am
I was getting 300km to a tank - 320 at best with 30" KM's Auto VVT Transfer and my 1.3
I haven't finished a full tank on my 1.8 yet - back tot he stock transfer and 30" KM2's
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jan 24, 2014 10:14 am
JK what pressure were you running? i was geting about that with 26PSI
Post Posted: Fri Jan 24, 2014 10:20 am
28-30 psi difference is I carry a lot of crap at any time - tools ETC
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jan 24, 2014 10:31 am
i was also wondering what runing a jimny throttle body does in terms of economy on a M15.
the WOT power figures would have to be lower with the jimny throttle body has more restriction *then the m15 body8, but when the butterfly is the point of restriction (and assuming the air:fuel ratio is maintained) the only extra energy loss is a marginal increase in friction from the additional piston circumference so fuel economy should be fine unless your at WOT. in effect it would be harder to labour the engine.
*edit*
Vehicle: 2006 M18A VVT auto Jimny
Post Posted: Fri Jan 24, 2014 6:34 pm
235's auto vvt m18 get about 300kms running 98. A bit more if I up the tire pressure but you feel it on road.
Post Posted: Mon Jan 27, 2014 8:58 pm
Around 265 klm per tank (~34L) 2008 M13A VVT 33" x 12.5" tyres running 25psi front & 29psi rear
Users browsing this forum: No registered users and 300 guests
