It is currently Fri Oct 30, 2026 7:37 am
Post Posted: Fri Jan 24, 2014 4:19 pm
Well its come time to start planning my trip to VIC adventure tour. Im thinking of taking the Fiddy down and so to avoid disappointment when i get down there and break something I need a list. Suggestions???
tyres x 2
axles/ cvs
two stroke oil
tail shafts and jack shaft
Spare Diff (welded)
Post Posted: Fri Jan 24, 2014 4:29 pm
tyres no just spare if you want
axles yes
two stroke oil yes lol unless you think you don't need it
tail shafts I wouldn't waste your time unless you break them a lot
diff see above
I normally rip brake lines out
others seem to do transfer mounts engine mounts etc
Post Posted: Fri Jan 24, 2014 4:58 pm
Zip-ties
Brake fluid
test light
Fuses
Esky
Spanners
Shifter
Hammer
Spare top leafs
Bit of water
Good times will bring themselves.
Post Posted: Fri Jan 24, 2014 5:21 pm
Spare fuel pump, radiator/hoses, tail shafts and axles are about the only things that you couldn't scrounge/bodge easily, assuming you'd call it game over if you lunched an engine or gearbox.
Post Posted: Fri Jan 24, 2014 5:53 pm
plugz
Vehicle: Tintop sierra 31's
Post Posted: Fri Jan 24, 2014 7:37 pm
Gwagen made a list on vic site
Post Posted: Fri Jan 24, 2014 7:39 pm
And may I add it only includes anything for a trackside possible repairs, and keeps tools to a surprising minimum. I have everthing on it and never needed anything else
Post Posted: Sat Jan 25, 2014 12:20 pm
Most tools will be on hand, so I'd only bother taking basic tools you'll want to grab quick to tweak something, or anything that's specific for your car.
As for spares, most failures on AT fall into bearings/Axle/CV/Uni, or fuel/electrical - so make sure the charging system is up to scratch, and the starting system. A spare alternator and starter to have a camp wouldn't go astray. Make sure you know what's in your electrical system in terms of repairs/mods/bugs. Make sure you have plenty of fuses if your 50 runs run glass like the early 1.0 litre cars - not many people carry glass fuses. If you run a thermo, triply check it's up to scratch. Likewise the fuel pump if you're running electric/non standard.
I don't think anyone on trip will know anything at all about the 50's oil system or be able to help at all with it if you have issues, but I'm sure you're across it. Maybe some plugs, a coil, stuff like that. Most of us will be running T coils with EFI/coil pack cars so we won't have a 1.3 carby coil handy if you have trouble.
You've probably driven the 50 is terrain as hard as anything you're likely to see, so you should know its weak points by now in relation to driveline, so mostly, basic stuff to keep it running.
Whilst it's only three days of driving, and we don't always see all that much breakage, we do see a lot of niggly problems come to the fore on tour. I think it's just that it's three days back to back that brings things to the fore - if something occasionally gives trouble or you weren't; sure about something, it will let you know on tour.
Having said all that, trackside fixes are a ingrained part of the tour. We don't like to see anyone have to pull out.
Post Posted: Mon Mar 17, 2014 6:05 pm
The Suzuki 4wd Club Victoria Adventure Tour 2014 has now come and gone.
Refer to the Trip Thread here to see how Tanshi survived 3 days on a very dry and dusty tour:
viewtopic.php?f=3&t=45491
Users browsing this forum: No registered users and 303 guests
