It is currently Fri Oct 30, 2026 12:07 am
Post Posted: Tue Jan 28, 2014 8:46 am
according to searches between the NT - WT chassis width's this is possible where this thread should go.
i am interested in bolting up a GV nudge bard to a XL7... -- not a bull bar and actual nudge bar like the pram handles good for bumping into a sapling OR mounting a light to that's it!!!any takers that would know if this is a generic fit they're the same measurements ? OR...
can i get somone with a GV to measure the mounting points between chassis rails and such so i can measure mine and see if they fit??
i'd appreciate that a fair ammount.
if required -- 2000 GV -> 2004 XL7
Vehicle: 99 Grand Vitara
Post Posted: Tue Jan 28, 2014 12:53 pm
If you have the 4 bolts or tapped holes on your front crossmember (under your radiator), it should fit. I'm pretty sure that's where I had mine on
http://www.strictly4x4.com.au
Post Posted: Tue Jan 28, 2014 1:34 pm
on the cross member??
doesn't the nudge bars mount into the chassis rails?
i'll climb under my car tonigth and get some photo's of where i'm assuming it SHOULD go!!! see what people think
Vehicle: SWB Sierra
Post Posted: Tue Jan 28, 2014 1:53 pm
One bolt goes through the chassis rail, I think the second uses one of the bolts for the suspension sub frame.
I'll get some measurements when I'm in the garage tomorrow.
Post Posted: Tue Jan 28, 2014 5:04 pm
Yours has air bags yes? So you want the brackets that go back through the centre of the chassis also!
I had a tjm nudge bar on my gv when i got it.
Users browsing this forum: No registered users and 138 guests
