It is currently Fri Oct 30, 2026 8:58 pm
Vehicle: Want a zook
Post Posted: Thu Jan 30, 2014 9:15 am
Hi. I have a wt 1.3 swb sierra.
It has a 2" body lift but the rubber oem bushes used are shot. Loads of movement in them and brittle.
I know low range and a couple of other places do full polyurethane body mount kits for 100 bucks.
I have also found the factory oem kits for 150-200.
My question is does anyone know where I can get them in Australia. All I have found is the states.
My local suzuki place suzi sport in lawnton qld were supposed to be ordering me a kit but three weeks later still waiting.
If I buy a non oem kit how do I know which parts go where do they have instructions and is the polyurethane better than the oem
Vehicle: Drover pickup turk
Post Posted: Thu Jan 30, 2014 9:24 am
just_cruizin does body rubbers, I bought some from him the other week because of the same issue.
viewtopic.php?f=15&t=15518
EDIT: This should help with the location, Basically replace what you pull out.
86slowsierra wrote:
Yeah i had the same problem too. i believe that it important to have all rubbers in place as the sierra body moves a lot and can crack if unsupported.
this is from when i asked http://www.auszookers.com/forum/viewtop ... ody+mounts
(How do you make the clicky blue text? the globe icon is gone)
Ok, so this is kinda how i did mine. All mounts were attached with sikaflex to the chassis.
* black circles are thick square ones.
The front 2 mounts are 15mm apox square rubber mounts that are bolted down.
The diagram should help with the bulk of the rest.
however the rear 2 mounts i used circle rubber mounts, bout 5 mm thick , from memory.
Basically if you put the 8 main ( front, rear, 6 in the guts) mounts in, then stuff whatever fits into the remaining spots.
I like the tuna here
Vehicle: SJ80, SE416
Post Posted: Thu Jan 30, 2014 4:31 pm
X2... I'm pretty sure his kit are thicker than stock ones also giving you slightly more lift!
Users browsing this forum: No registered users and 488 guests
