It is currently Fri Oct 30, 2026 10:03 am
Vehicle: Coily.
Post Posted: Mon Jan 27, 2014 8:33 pm
I've done a search and was in the process of boring a hole to try and clean out heater core as water is pouring in from behind glove box when it rains.I noticed a square plastic box on side of heater(top of passengers feet) that looks like it has clips and was wondering what it is and if there's a filter inside?.Any help would be appreciated as i can't find drain tubes either. TIA
Vehicle: 92 tintop sierra
Post Posted: Mon Jan 27, 2014 11:39 pm
Im doubting it has a pollen filter .
In the case of leaf sprung sierras the drains are in the engine bay on the firewall . Put your finger up these and feel for crap blocking them up.
Vehicle: WT sierra, GU CRD
Post Posted: Mon Jan 27, 2014 11:53 pm
Square plastic box with clips on it, above passengers feet. In my leafy this is the A/C.
This.
Although mine still leaks after cleaning them, most people resort to plating this up.
I love ZD30. :)
Vehicle: 1997 Sierra SJ80
Post Posted: Tue Jan 28, 2014 7:30 am
Take the grill below the windscreen off, and remove the tray. Check for cracks etc?
Vehicle: SJ80, SE416
Post Posted: Tue Jan 28, 2014 11:18 am
Yes, take that gill off (just a few push-in clips holding it in), but no need to remove anything else and get a garden hose and clean out the drain flap which drains excess water into the engine bay.
I have found the drain flap gets a bit 'sticky' and doesn't drain at all after being clogged with dust, henceforth water running onto the passenger floor after a highspeed r/h corner.
Post Posted: Tue Jan 28, 2014 12:15 pm
Same goes for a leafy?
I love ZD30. :)
Vehicle: Coily.
Post Posted: Tue Jan 28, 2014 1:27 pm
Thanks for all the replies,i'll give it a go before boring holes as the heater still works.
Car doesn't have Air,it looks like a square box with clips but will try & take a photo.
Post Posted: Tue Jan 28, 2014 1:34 pm
I don't remember a leaf Sierra having removable plastic clips, but same principle. I'm pretty sure on my Stepfathers Sierra we just used forced water from a hose into the grill beneath the windscreen to clear it out.
Post Posted: Tue Jan 28, 2014 1:52 pm
Tin top leafy definetly doesnt have a removable grille below windscreen.
I took my heater box apart and cleaned it out properly and replaced all the foam seals.
Post Posted: Tue Jan 28, 2014 5:25 pm
Oh, I thought you were meaning to take the dash apart from the inside.
Nothing unbolts from the outside thats for sure.
I love ZD30. :)
Vehicle: Suzuki Sierra 1996 SJ80
Post Posted: Tue Jan 28, 2014 7:37 pm
had same problem. the black grill under windscreen, take that off and fell for gunk and shit in there. clean it out = problem solved
Users browsing this forum: Google [Bot] and 236 guests
