It is currently Thu Oct 29, 2026 2:23 pm
Post Posted: Wed Feb 05, 2014 3:43 pm
I have heard/seen on a couple of websites that jimny and sj80 front control arms are the same. Does anyone know if the rears are the same? And/or does anyone know a company that makes upgraded rear arms for sj80?
Vehicle: SJ80, SE416
Post Posted: Wed Feb 05, 2014 4:19 pm
Pretty sure the rear is different. Suzi Auto had a set of tubular arms for a coily on their shelf for a long time. They might still be there. IMO the arms are stronger than the diff mounts and chassis mounts so aren't really something which needs upgrading. Spare ones are easy enough to obtain as they can get a slight bend in them but I never had a problem and have never used a spare because the arm broke or bent.
Post Posted: Wed Feb 05, 2014 5:57 pm
hi Reubs, about two years ago I broke rear right diff mount, got it repaired and lightly braced. A year later the diff bent from a trip up the cape (probably due to too much weight and corrugations/dips). I got a new diff braced and the mounts braced again.
I was out wheelin on the weekend. a steep hill which went wrong bent the arm. We straightened it but it broke later in the afternoon.
I am looking for a set of original arms to replace and to keep a spare, but through i would see what else is out there
Post Posted: Wed Feb 05, 2014 6:27 pm
Snake racing used to
Post Posted: Thu Feb 06, 2014 7:06 am
Jimny rear arms are longer.
Vehicle: Suzuki Sierra 1996 Coily
Post Posted: Thu Feb 06, 2014 2:22 pm
4xfourart suspension has them in a kit, not sure if they are sold separately and you would have to import them but they look a lot stronger then standard
Post Posted: Thu Feb 06, 2014 4:34 pm
i only see kits for Jimny's. I think i am going to have to go with the info from joeblow that the jimny arms are longer unless i hear otherwise
Post Posted: Thu Feb 06, 2014 8:30 pm
yeah you will have to contact him to see the sj80 kit
Post Posted: Thu Feb 06, 2014 10:06 pm
I have some stock jimny arms in the shed, can put a tape measure over them if it will help
Users browsing this forum: Google [Bot] and 310 guests
