Hi guys dont know if anyone can help ... and ive scoured the internet myself ...
I am after the pcmcia card file for a tech 2 to do the key registration process on a 1.9 tdi 2010 grand vitara , i have found it for models up to 2008.
Alternatively , the immobiliser connection cable for the genuine suzuki SDT scanner which is marginally cheaper than the one i found for nearly $4000.
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
Posted: Wed Feb 12, 2014 6:10 pm
I don't think thta you can get any support for a Tech 2 beyond 2008 because it was replaced with the SDT. Neither the SDT nor the Tech2 will be of any use to you unless you can login through the Suzuki dealer service network because thats the only way to get a password. Does the immo sit on the CANBus or is it on pin 9?
had a locksmith guy out today and with all his equipment he couldnt even access the immobiliser to program the key , we have a SDT scanner but not the immobiliser harness , and a tech 2 with the pre 2008 software . so we are screwed , off to suzuki ?
Users browsing this forum: Google [Bot] and 393 guests
