It is currently Thu Oct 29, 2026 11:37 am
Vehicle: 1996 swb Vitara Soft top
Post Posted: Wed Feb 12, 2014 9:50 pm
Can anybody tell me which is correct airflow pipe for 5/1996 SWB Vitara.with G16B Engine
When I purchased car it had K&N filter on it & black rubber air pipe.However local garage refused a blue slip & told me to flick the K&N and put it back to standard!!
I purchased one online from a Suzuki wrecker & provided him with my VIN & was provided with the black rubber air supply pipe
I also bought an air box of him but already had the air sensor.
However when I came to fit them up the air box fitted in OK but the oxygen sensor when fitted into air box was a very loose fit.
Also the plastic/rubber air flow pipe seems to be to long and has to be really rammed up against throttle body to try & get the two locating bolts into place.
Had a look on web &it appears the 1996 cars had a metal air flow pipe & a different type hose (slightly bent) into air box.
Have I been sold wrong air pipe?? I know I could try to modify what I have but would like to put correct parts back on.
Have tried to locate part number for either rubber or metal air pipe with no luck.
Last 4 numbers of my VIN are 1275
Thanks in advance.
Dusty
Post Posted: Thu Feb 13, 2014 6:08 am
96 vits are a bit special, but it should be a plastic pipe and yes its tight, try loosening the bolts holding the bracket you need to bolt the hose too off a bit first
Users browsing this forum: Andygoodbloke, Google [Bot], Jezzer and 425 guests
