It is currently Thu Oct 29, 2026 10:51 pm
Vehicle: 1998 Suzuki GV
Post Posted: Fri Feb 14, 2014 8:11 am
hey guys,
I have just recently purchased a 2.5 98 GV and have noticed the Check engine light randomly coming on.
It happens when i'm on the highway usually about 100-110 kph with just enough throttle to cruise (about 1/4) after 30 seconds or so the check engine light will come on and will stay on until i either accelerate more or take my foot off the throttle.
Any ideas?
I was going to get a code reader from my mechanic but unsure if this car will store the code in a memory and i cant ALWAYS make it happen.
Mikey.
Post Posted: Sat Feb 15, 2014 6:45 am
The chances of your mechanic having a code reader compatible with your 98 GV are not very high, however, you can insert a paperclip into a socket near the right strut mount and the ECU will flash the codes on the check engine light - see http://www.rhinopower.org/ for more details, and you can also purchase an interface from Rhinopower and download the software to get the codes using a laptop.
Chances are that one or more of your O2 sensors (if fitted - not all 98 GVs will have them) is on the way out.
Post Posted: Sun Feb 16, 2014 7:36 pm
I did read that website to check but didn't quite understand how to do it.... :cry:
Any chance you could give me a run down on how to do it? :youdaman:
Vehicle: 2004GV + bar + custom mods
Post Posted: Sun Feb 16, 2014 9:36 pm
thiis can help
http://auszookers.com/forum/viewtopic.p ... hilit=plug
so can search at the top
Post Posted: Mon Feb 17, 2014 1:16 am
1) Insert paperclip
2) Switch on ignition
3) Count flashes of check engine light
4) Look up flash code in chart.
Post Posted: Thu Feb 20, 2014 12:51 pm
Havnt had the code checked yet but had a chat to the previous owners and they said this has been happening for about 15 years....... and has never changed. odd.
Post Posted: Thu Feb 20, 2014 1:43 pm
Post Posted: Thu Feb 20, 2014 4:59 pm
So pretty much since new?
Post Posted: Fri Feb 21, 2014 12:44 pm
From approx 1-2 years old.
Post Posted: Fri Feb 21, 2014 12:48 pm
Did you head butt them for not getting it fixed under warranty!? :lol:
A Suzuki dealer is probably your best option for getting the code read - if you can't work out the other method?
Users browsing this forum: No registered users and 315 guests
