It is currently Thu Oct 29, 2026 12:30 pm
Post Posted: Sun Feb 16, 2014 7:46 pm
I'm looking to buy a set of alloy beadlock rims, but due to jimny steering knuckles and and tight guards I can't have much offset.
So I know the 15x7s with -0 offset rub, but only just;
But if I bought 16x8s with -0 offset will the extra diameter clear the steering knuckle?
I would prefer 16x7s but can't find any, even better for tyre choice is 15x7s but I can't find those either.
Wilso.
Post Posted: Sun Feb 16, 2014 7:54 pm
Are you totally fixed on alloy? I'm pretty sure you can get 16x7 steel beadlock rims?
Post Posted: Sun Feb 16, 2014 8:25 pm
I already have steel beadlocked rims... Why not loose some weight I guess...
Post Posted: Thu Feb 20, 2014 8:03 pm
So I take it not then... well here goes an expensive experiment...
Post Posted: Thu Feb 20, 2014 10:49 pm
have you checked the weight differences? I looked into 15x7 alloys vs. 15x7 steel rims and the difference was bugger all...
Sure, the rings for the locks would make a difference, but the alloy ones would still need to be thicker than the steel ones for strength.
Vehicle: 1997 Sierra SJ80
Post Posted: Fri Feb 21, 2014 7:16 am
I is fairly sure, that Allied would be able to do something, as they use alloy blanks, so they can machine to whatever stud pattern, CB, and offset you want. (within reason)
But as a custom set, there would be a premium to pay.
You would still need to buy through a dealer, but you should be able to ask Allied, and get some feedback as to feasability.
Allied Wheels Pty Ltd
5 Business Drive
Deception Bay QLD 4508
(07)3293 4500
Post Posted: Fri Feb 21, 2014 10:52 am
http://www.alliedwheels.com.au/collecti ... atin-black
Yeah 114.3, -13 and Its not a custom job. Plus with the extra weight I welded only an already heavy steel wheel I can't see the alloy being anywhere near as heavy...
Thanks fellas I think ive got a hook up with the tyres and rims so hopefully ill have it done soonish.
Post Posted: Fri Feb 21, 2014 4:02 pm
If you haven't already, make sure to confirm that they are an actual beadlock.
Post Posted: Fri Feb 21, 2014 8:26 pm
Cheers, matty informed me those were not this arvo lol
Looks like im getting savannahs...
Post Posted: Sat Feb 22, 2014 5:45 am
Yeah looks like I'm going to have to settle for savannahs as well, I'm onto three Chinese manufactures but I need to buy min fifty pieces, anyone want some alloy beadlocks that look like the wheels on my LJ ?
Post Posted: Sat Feb 22, 2014 6:05 am
Why Allied?
Post Posted: Sat Feb 22, 2014 7:50 am
Method do 15x8s and a heap of them
http://www.methodracewheels.com/collections/race-wheels
Evan walkers are only $375 a piece, prolly cheaper then buying 50 :lol:
http://walkerevansracing.com/products/2 ... heels.html
Post Posted: Sat Feb 22, 2014 12:10 pm
Has anyone found 16x6 or 16x7 flash rims for a jimny?
Vehicle: 2006 Jimny 4" Lift
Post Posted: Sat Feb 22, 2014 6:50 pm
I'm with you Shep, chasing 16x7 or 16x6 with like a -15 to -20 offset to run 750 R16's or 215/85R16's on as they have the lift im chasing but not the width, would gladly stick with a 15" rim but there is just nothing in skinny tyres all 9.5, 10.5 or wider, may look cool but ruins fuel effciency with the extra weight and road resistance
Post Posted: Sat Feb 22, 2014 7:43 pm
Are any of the 16" GV rims the right offset?
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Feb 22, 2014 7:54 pm
Pretty sure there is a gv wheel that fits, but not all of them do. There's a thread somewhere. Be basically the same as fitting gv wheels to a Sierra.
Post Posted: Sat Feb 22, 2014 8:18 pm
Steaky had 98/05 gv rims on his jimny
Users browsing this forum: No registered users and 379 guests
