It is currently Sat Oct 31, 2026 8:50 pm
Post Posted: Tue Feb 18, 2014 3:04 am
I know a few of you guys have done this conversion before.
Just after some ideas and pics of how to fab the gearbox mount (I want to keep the factory mount if possible).
It's going into a swb sierra.
Thanks in advance.
Post Posted: Tue Feb 18, 2014 5:56 am
I'm on my phone ATM- check the trolley tug build. We made our own close out plate, but you can now buy the required bush from trail tough. The box definitely fits with the stanadard gearbox crossmember in place.
Vehicle: 92 Sierra and GQ Patrol
Post Posted: Tue Feb 18, 2014 12:14 pm
sorry for the hijak, do these trimatics share anything with the holden ones?
For example could you put a RWD output housing from a holden trimatic on to the output of the vitara trimatic?
Post Posted: Tue Feb 18, 2014 12:34 pm
I'm not sure if the cases are interchangeable with Holden versions, lots of the internals are.
Vehicle: LJ50V 2 stroke
Post Posted: Tue Feb 18, 2014 1:29 pm
cases are different, kick-down cable is missing on the holden case, the range selector is on the other side and it has and extra couple of wires
as far as the internals go the output shaft is a different length, input shaft splines are the same (as link as you don't have a torque converter lock-up) every thing else "looks" the same.
Post Posted: Tue Feb 18, 2014 1:36 pm
CHeers guys, Yeah I thought the output shaft maybe be the killer as just looking at photos the bolt pattern looks similar
Post Posted: Thu Feb 20, 2014 7:33 pm
Thanks Steve!
Post Posted: Mon Mar 03, 2014 4:28 am
Do I use the sierra or swift flywheel for the auto?
Post Posted: Mon Mar 03, 2014 5:38 am
Neither. You need the flexplate from the vitara. Autos don't use flywheels.
Post Posted: Wed Mar 05, 2014 6:07 pm
Will the swift/baring flexplate and torque converter be the same as a vit?
Post Posted: Wed Mar 05, 2014 7:39 pm
I'd say there's zero chance of that.
Users browsing this forum: No registered users and 100 guests
