It is currently Thu Oct 29, 2026 12:41 pm
Post Posted: Fri Feb 21, 2014 4:05 pm
hay people iam trying to take of the nut on the front diff i have been trying for the last hour i have even tried the air compressor and not moving a mm any ideas????
Post Posted: Fri Feb 21, 2014 4:07 pm
the pinion nut? you need a really big rattle gun.
the other question is why do you wanna undo it?
Post Posted: Fri Feb 21, 2014 4:09 pm
need to replace the seal and iam using a rattle gun
Post Posted: Fri Feb 21, 2014 4:14 pm
dont undo that nut.
you need to replace the crush tube if you do.
your diff will loose all the preload on the pinions bearings and the diff will wear prematurly.
Post Posted: Fri Feb 21, 2014 4:18 pm
how do i fix the oil leak from there
Post Posted: Fri Feb 21, 2014 4:39 pm
without replacing the crushtube you cant.
Users browsing this forum: Google [Bot] and 401 guests
