It is currently Thu Oct 29, 2026 6:30 pm
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Feb 26, 2014 7:53 am
the following got me thinking about what we collectively know
monley wrote:
jimny_timmy wrote:
An hour an end should kill it. I reckon they will bolt in, there will be some redundant plugs for the abs wheel sensors on the 2012 diffs.
Not sure on diff ratio.
Ratio will be the same unless it's from an auto.
98-2004 ratio is 4.11
2005+ is 4.3
All autos were 4.3
if we assume both 2005+ manual and auto jimnys have the same diffs, (and we know they have the same 205/70r15's stock) then the speedo ring on the output shaft of the transfer case would be counting the same number of revolutions and the speedo would read that and display it.
now unless the ratios are different in a auto, why does a auto transfer case in a manual read 100kph at 100gps, with 30xp.5"tyres. this is a 13% decrease in gearing.
whether the diff ratio is different, or the speedo ring is different, or both, something needs to be happening to counteract the larger tyres.
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Feb 26, 2014 9:00 pm
Auto diffs are diff to manual in all models... My slip up on the 05+ bit :(
Users browsing this forum: No registered users and 79 guests
