https://auszookers.com/forum/
wheel hub bearing inner race
https://auszookers.com/forum/viewtopic.php?f=5&t=45300
Author:  coily96 [ Fri Feb 28, 2014 6:03 pm ]
Post subject:  wheel hub bearing inner race
Just removed the hubs to do bearings and seals, i removed peices in this order: circlip, inner race x2, bearings fell out now im left with this.
Question is do i still have the outer race left in the hub, i can see JAPAN on the lips.
Author:  coily96 [ Fri Feb 28, 2014 6:29 pm ]
Post subject:  Re: wheel hub bearing inner race
New bearings on left, old on right. I think the large rings on left is the outer race and need to go in the hub after the old races have been pressed out?
Old style bearings vs new tapered roller bearings.
Author:  xl76 [ Sat Mar 01, 2014 10:19 am ]
Hello
Get a brass drift or punch and move in a circle and tap the old one out. to install do the same working in a circle tap the new one in should only take a couple of minuets
