It is currently Tue Oct 27, 2026 6:32 am
Vehicle: 1996 Leaf Sierra - Soft Top
Post Posted: Thu Sep 25, 2014 7:49 pm
So I discovered this new leek out of my rear diff near the uni joint. Does anyone know the name of the seal that needs replacing so I can order a new one ASAP. And does anyone know the difficulty of replacing this?
You can see it's sprayed diff oil everywhere. :rambo:
Thanks guys!
Thomas
Post Posted: Thu Sep 25, 2014 7:54 pm
Pinion seal.
When you remove the flange you should put a new crush sleeve in there to maintain proper bearing preload.
Vehicle: 85 ' Drover
Post Posted: Thu Sep 25, 2014 8:08 pm
I just replaced mine. I pulled the centre out of the diff and took it to a diff shop. Cost me $110 including a new seal and for them to set the preload on the pinion bearings. I would avoid trying to change it yourself, if you get that preload wrong you'll be up for way more than $110.
Post Posted: Thu Sep 25, 2014 8:10 pm
Thanks for that! Is that something I order specifically for this car or something different? Sorry not too sure what it is, haven't pulled one apart before.
Post Posted: Thu Sep 25, 2014 8:13 pm
This sounds like a safe option. As I have minimal knowledge about diffs!
Is this the type of seal that just dies after time?
Would you/anyone recommend replacing any other seels that usually go around the same time as this?
Thanks!
Post Posted: Thu Sep 25, 2014 8:18 pm
No other seals really, it's a lip seal that just wears out. You could replace the lip seals at the wheel end of the diff but generally with lip seals if they aren't leaking best to leave them alone.
Just let the diff shop supply and install the seal.
Post Posted: Thu Sep 25, 2014 8:20 pm
Okay too easy! Thanks.
And also, I shouldn't drive it right? It's sprayed a fair bit of oil don't want to cause damage
Post Posted: Thu Sep 25, 2014 8:24 pm
The only issue is the diff running out of oil. If you are happy with the mess there's no issue with short trips and just top up the oil if required.
Post Posted: Thu Sep 25, 2014 8:26 pm
Alright so as I thought! I'll probably just leave it to be safe anyway!
Thanks heaps for the help!
Post Posted: Thu Sep 25, 2014 8:52 pm
Did the leak start after you let the car sit for a while? Mine was interesting in that it started leaking like a siv after the car sat for 2 months or so, then when I started driving the seal came good. I changed mine anyway and the diff shop reckoned the seal looked fine. I suspect the seal dries out and starts leaking. Then when you start using it again the seal "un dries" itself. This sAme thing happened on the axel lip seals on my old corolla. Weird things the ol' lip seals.
Post Posted: Thu Sep 25, 2014 9:09 pm
*seal
Post Posted: Thu Sep 25, 2014 10:42 pm
Haha wow.. thanks Atari! (:
And nope. Been driving it pretty heavily actually, so maybe that's why! Good to know that though. Strange things for sure!
Users browsing this forum: Google [Bot] and 210 guests
