| 1.3 suzuki alternator 2 pin to 3 pin https://auszookers.com/forum/viewtopic.php?f=5&t=45668 |
| Author: | motovamp27 [ Mon Mar 31, 2014 4:32 pm ] |
| Post subject: | 1.3 suzuki alternator 2 pin to 3 pin |
how do i wire up a 3 pin altrernator to a 2 pin plug im lost and need help |
| Author: | johnmath [ Mon Apr 07, 2014 6:01 am ] |
| Post subject: | Re: 1.3 suzuki alternator 2 pin to 3 pin |
AFAIK, the third wire is the voltage sense wire and should be connected to battery +. Anyone else? |
| Author: | losfer [ Mon Apr 07, 2014 7:27 pm ] |
the third will be a ground terminal which wont be needed . the three pins should be B,G and IL . the B is battery and will be a black with a white stripe , the IL will be a white with a red stripe , this is the Ignition Lamp , it feeds voltage to the battery light in your dash and goes out when the alternators diodes get excited and starts charging your battery . The G is of course Ground its not needed .... |
