| suzuki Baleno engine into Sierra? https://auszookers.com/forum/viewtopic.php?f=5&t=45815 |
| Author: | zookpower [ Wed Apr 09, 2014 10:22 pm ] |
| Post subject: | suzuki Baleno engine into Sierra? |
hey guys just wondering ho has done it, whats involved, whats parts are needed, gearbox used and if its actually worth doing? Cheers |
| Author: | SuziBlu [ Fri Apr 11, 2014 3:34 pm ] |
| Post subject: | Re: suzuki beleno engine into sierra? |
Everyone loves this, fair bit of work, but rewards are huge. Look for a later one, coil pack, far better, your choice of gear box, vitara is bigger, stronger, but requires cutting and rewelding the firewall and gearbox zone, they are wider. http://www.auszookers.com/forum/viewtop ... 15&t=15009 I have nothing but the very highest praise for this mans work, its stunning, you will need his adapter, get it. Im not real good with the search engine, cant even find me, doh. There are quite a few write ups, http://www.auszookers.com/forum/viewtop ... =17&t=6423 here is one, but there are others. You will need a wiring change, buggered if I know where to find that, hopefully someone will help, only a few hundred dollars, major PIA saviour. you will get a much much more powerful motor, both horsepower and most importantly torque, more modern, better in everyway. Go for it. |
| Author: | Teracis [ Fri Apr 11, 2014 8:56 pm ] |
| Post subject: | Re: suzuki Baleno engine into Sierra? |
The wiring conversion that you can pay for he is talking about is probably the one from Killa Kustom Cables if I remember correctly. A few people here have used them and reports are good, also if something goes wrong they don't mind helping you work it out by the look of things. I can't tell you yet how hard the wiring will be as I'm not that far into it yet but it's not rocket surgery so if you understand electrics at all you should be able to work it out. |
