Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
94SJ70Zook
Vehicle: Suzki Sierra 94 SJ70
 Posted: Thu Apr 10, 2014 7:19 pm |
I need some advice about how I can remove my drums on my Sierra. It has been sitting for quite a while and they have seized. I have just managed to get one of them to turn freely by using heaps of WD40 and hitting the drum with a rubber mallet but the other one is super stuck. I have been told to use a small hole in the rear of the brake housing to access the shoes and mechanism with a screw driver. When I stick the screw driver in I can't find anything to free the shoes. I hope you know of the hole I am talking about, It has a small rubber lug seal. What should I be doing? And once I get them turning freely, how do I remove the drum? Should it come off by hand?
Any advice would help as I am an ameteur at this stuff.
Thanx
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
Vehicle: 03 Jimny
 Posted: Fri Apr 11, 2014 12:34 pm |
Try using the jacking bolt holes in the drum. Tighten bolts up and tap with mallet and repeat. That should get the drum off.
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
94SJ70Zook
 Posted: Sat Apr 12, 2014 12:57 pm |
The jacking bolt holes?? She's stuck fast. Does anyone know about the small hole on the back of the backing plate? A brake expert told me to access the shoes from there to back them off. I have one spinning free. I just want to get them both free so I can take it down the road to the brake shop.
killazook
Vehicle: 92 wt soft top sierra
 Posted: Sun Apr 13, 2014 8:58 am |
Is your handbrake on while doing this and way I get them of is flog em with the mallet wat also works is put a nut on one of the wheel studs and use a pry bar to lever off one of the drums studs I hope that made sense
94SJ70Zook
 Posted: Sun Apr 13, 2014 1:46 pm |
Thanx, i belted the crap out of one and got it off but the others still stuck, i'll try that. Thanx for ur help
rockcrawlerdude
Vehicle: 1985 LWB sierra
 Posted: Sun Apr 13, 2014 2:03 pm |
Release hand brake, put the wheel back on and wiggle it off, or use it as a sliding hammer.
coily96
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
 Posted: Sun Apr 13, 2014 10:10 pm |
Leave outer wheel nuts tight and undo 4 inner nuts.
Kick wheel side to side but make sure the car is well supported. The wheel should fall off with the drum stuck to it.
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 589 guests
