Hi all. Just got back into a suzi. Bought an 05 jimny and love it. But having an issue with the hubs. All the vacuum side of things is working fine but the actual sliding gear remains engaged when the vacuum hub retracts leaving the hubs in 4wd always. If I pull the hub off and slide the gear back its all good... until I put it in 4wd drive again and it does the same thing. Is this gear supposed to be anchored to the outer section of the hub in some way? It seems that there is nothing to move the actual gear out when the hub retracts. Hope that makes sense.
Users browsing this forum: Google [Bot] and 349 guests
