| Vitara Power steering pump banjo bolt size? https://auszookers.com/forum/viewtopic.php?f=5&t=45904 |
| Author: | Blkfxx [ Wed Apr 16, 2014 7:08 pm ] |
| Post subject: | Vitara Power steering pump banjo bolt size? |
I did post this in the power steer install thread. Does anyone know what size the banjo bolt is on the pump? As I have misplaced mine. |
| Author: | buzbox [ Wed Apr 16, 2014 7:20 pm ] |
| Post subject: | Re: Vitara Power steering pump banjo bolt size? |
I did see that you can get a replacement off lowrange, but obviously Pirtek is quicker.. If I don't have a "memory failure" I'll measure it tomorrow. |
| Author: | Blkfxx [ Tue Apr 29, 2014 8:48 am ] |
Bump |
| Author: | jdk81 [ Tue Apr 29, 2014 2:41 pm ] |
I hope this is enough info external diam 16mm int diam 10mm 13mm shank (from base of bolt head to start of thread) 30mm long over all (shank and thread) 22mm bolt head 7mm thick bolt head 4 holes 6mm diam (2 holes straight through) 2 at 7mm from base of bolt 2 at 10mm from base of bolt using 2 x 2mm thick copper washers |
| Author: | Blkfxx [ Tue Apr 29, 2014 4:44 pm ] |
Wicked! jdk81 to the rescue once again, Cheers mate. Hopefully with that info and the pump in hand I'll be able to get a replacement. |
