| Need help sc14 supercharger https://auszookers.com/forum/viewtopic.php?f=5&t=45916 |
| Author: | RT001 [ Fri Apr 18, 2014 10:05 pm ] |
| Post subject: | Need help sc14 supercharger |
Hi guys can any 1 help I am trying to fit a sc14 on My jimny 05 vvt Need pulley sizes and max boost on stock motor Was thinking 5 psi |
| Author: | 31zook [ Sat Apr 19, 2014 8:34 am ] |
| Post subject: | Re: Need help sc14 supercharger |
You will probably be allot better off on a toyota forum ad there is heaps of jimnys here but not many SC14 builds. When you do work it out, please share |
| Author: | jdk81 [ Sat Apr 19, 2014 9:41 am ] |
At 5 psi, pulley size needs to be 61% of the harmonic balancer (jimny crank pulley) No idea how long the stock engine will last. Using this thread, and changing the 1.6 to 1.3. viewtopic.php?f=5&t=22152&hilit=boost IMO The sc14 is probably too big, an amr500 would be better. It would be an metric assload easier and more reliable to fit a bigger m series engine. |
| Author: | shep [ Sat Apr 19, 2014 10:42 am ] |
I plan on supercharging mine however I will be buying a compleat solution from here http://www.bulletcars.com/superchargers/suzuki/ |
| Author: | suzukiboy [ Sat Apr 19, 2014 1:48 pm ] |
shep wrote: I plan on supercharging mine however I will be buying a compleat solution from here http://www.bulletcars.com/superchargers/suzuki/ Saw the Bullet guy at the 4WD show in Brisbane, he will be coming out with a bolt up kit in the near future. |
| Author: | RT001 [ Sat Apr 19, 2014 2:27 pm ] |
Thanks guys |
| Author: | Dan85 [ Sat Apr 19, 2014 8:14 pm ] |
Ive seen some dyno sheets for a bullet jimny and it reckoned 80+kw at the wheels. I see drive train breakage! any way a jimny drive line will hold up to that sort of power? I know it depends on levels of mechanical sympathy but is there a way to beef up the drive line or if im keen enough to install a supercharger im getting solid axle hilux gear or similar installed? |
| Author: | henno [ Sat Apr 19, 2014 8:30 pm ] |
shep wrote: I plan on supercharging mine however I will be buying a compleat solution from here http://www.bulletcars.com/superchargers/suzuki/ Hold up. People are going to spend $6-8k (without even entertaining any driveline toughening up) to make a Jimny make not much more power than an M18 swap would provide? I'm all for spending money on toys (lord knows I've spent plenty) but that just seems like you'd reach the limits of the Jimny drive-line or the limits of your bank balance before it became a worthwhile expense. |
| Author: | shep [ Sat Apr 19, 2014 9:05 pm ] |
henno wrote: shep wrote: I plan on supercharging mine however I will be buying a compleat solution from here http://www.bulletcars.com/superchargers/suzuki/ Hold up. People are going to spend $6-8k (without even entertaining any driveline toughening up) to make a Jimny make not much more power than an M18 swap would provide? I'm all for spending money on toys (lord knows I've spent plenty) but that just seems like you'd reach the limits of the Jimny drive-line or the limits of your bank balance before it became a worthwhile expense. Firstly I don't drive like a ricer and I will spend as much as I want on my toy. Secondly what makes you think I don't have Plans for the rest of the driveline? |
| Author: | henno [ Sat Apr 19, 2014 9:09 pm ] |
Firstly, I have no issue with spending loads of money on toys, as I said. Secondly, beefing up the drive-line adds even more to the already exorbitant cost. Thirdly, see point one. |
| Author: | RT001 [ Sat Apr 19, 2014 9:14 pm ] |
It's all fun u make it go good then u fu&k it then u make it bigger and better go hard or go home |
| Author: | shep [ Sat Apr 19, 2014 10:11 pm ] |
A funny thing about m18 jimnys is when I drag raced one on a beach it had no advantage over my geared m13. So I fail to see the attraction of a m18 |
| Author: | monley [ Sat Apr 19, 2014 10:18 pm ] |
shep wrote: A funny thing about m18 jimnys is when I drag raced one on a beach it had no advanagte over my geared m13. So I fail to see the attraction of a m18 Really? Cus i had diffrent result when I raced a geared m18a Jimny on 31s against my geared m13a jimny on 31s |
| Author: | RT001 [ Sat Apr 19, 2014 10:34 pm ] |
Also any 1 no the best way to go with the comp piggyback or new aftermarket ecu |
| Author: | BlueSuzy [ Sun Apr 20, 2014 2:47 am ] |
monley wrote: shep wrote: A funny thing about m18 jimnys is when I drag raced one on a beach it had no advanagte over my geared m13. So I fail to see the attraction of a m18 Really? Cus i had diffrent result when I raced a geared m18a Jimny on 31s against my geared m13a jimny on 31s Its funny you think apples and oranges are the same sheep. Maybe they grow on the same tree up there. |
| Author: | shep [ Sun Apr 20, 2014 8:24 am ] |
monley wrote: shep wrote: A funny thing about m18 jimnys is when I drag raced one on a beach it had no advanagte over my geared m13. So I fail to see the attraction of a m18 Really? Cus i had diffrent result when I raced a geared m18a Jimny on 31s against my geared m13a jimny on 31s M18 was stock geared. Both on 30s |
| Author: | monley [ Sun Apr 20, 2014 8:31 am ] |
shep wrote: monley wrote: shep wrote: A funny thing about m18 jimnys is when I drag raced one on a beach it had no advanagte over my geared m13. So I fail to see the attraction of a m18 Really? Cus i had diffrent result when I raced a geared m18a Jimny on 31s against my geared m13a jimny on 31s M18 was stock geared. Both on 30s Hardly a fair comparison really then |
| Author: | jimny_timmy [ Sun Apr 20, 2014 8:44 am ] |
Why not supercharge the M18? Realistically it should all bolt straight to it |
| Author: | shep [ Sun Apr 20, 2014 9:14 am ] |
monley wrote: shep wrote: monley wrote: shep wrote: A funny thing about m18 jimnys is when I drag raced one on a beach it had no advanagte over my geared m13. So I fail to see the attraction of a m18 Really? Cus i had diffrent result when I raced a geared m18a Jimny on 31s against my geared m13a jimny on 31s M18 was stock geared. Both on 30s Hardly a fair comparison really then Why not? The end result was the same. |
| Author: | shep [ Sun Apr 20, 2014 9:16 am ] |
jimny_timmy wrote: Why not supercharge the M18? Realistically it should all bolt straight to it Because the m18 is a dodgy conversion using 1.3 intake and management, a compleat solution for the motor being used is in my opinion a much better option. If the end result is close enough to being the same then why settle for something that isn't quite right? |
| Author: | dougies_tx5turbo [ Sun Apr 20, 2014 9:58 am ] |
shep wrote: jimny_timmy wrote: Why not supercharge the M18? Realistically it should all bolt straight to it Because the m18 is a dodgy conversion using 1.3 intake and management, a compleat solution for the motor being used is in my opinion a much better option. If the end result is close enough to being the same then why settle for something that isn't quite right? In my opinion all the work supercharging and redoing the engine management system really isn't worth the time doing it to a 1.3. There is some information on the swift forums that the M15 is a much better motor to boost and holds better boost then M18's, there is ways of fixing little problems such as porting and polishing. Which another person had done on this forum. viewtopic.php?f=4&t=39370&start=180 And for the over fueling issue with the injectors that would be sorted when you re-do the engine management system. This doesn't apply to the above but they have fixed the throttle body problem on the stock motors. viewtopic.php?f=17&t=30308&start=210 It doesn't really matter you don't want to run to much power on a jimny drive train as they are not the strongest.but you can fix al these problems it just costs money. If you've got the money then why not. |
