It is currently Wed Oct 28, 2026 2:18 am
Vehicle: 92 softop w/GTi motor
Post Posted: Wed Apr 23, 2014 8:18 am
Anyone id this power steering box?
Bought a g16b that came out of a sierra with the power steering attached but it was fitted using a modified chassis rail instead of the ben t wedge.
I bought the kit and the bolts are in a similar pattern but look to be about 15mm out?Image
Sorry about the pic quality
Sent from my SM-N9005 using Tapatalk
Vehicle: 1985 LWB sierra
Post Posted: Wed Apr 23, 2014 12:39 pm
to me it dosnt look like a vitara steering box, i may be wrong though.
Post Posted: Wed Apr 23, 2014 12:41 pm
yep, not a vitara box.
might be cressida
Vehicle: 85 SJ413
Post Posted: Wed Apr 23, 2014 1:28 pm
Yeah, looks like it might be a Cressida steering box to me. Does it have "TOYODA" cast into it on the front?
I do an adaptor plate to fit those if it is a Cressida box:
Post Posted: Wed Apr 23, 2014 2:38 pm
Shit ben I just bought the vit kit off you last week off ebay.
I'll have a look to see if it's marked when I get home.how much is the cresida adaptor if I need it?
Post Posted: Wed Apr 23, 2014 2:49 pm
Ok it doesn't have 'toyoda' stamped but it definitely looks like the Japanese Toyota characters are.Image
Vehicle: 85 SJ413
Post Posted: Wed Apr 23, 2014 6:44 pm
It looks like a Celica box, and the pitman arm matches the Celica style with the balljoint built in.
I can do an adaptor for Celica boxes for $95 with the countersunk cap screws required to bolt it all up included.
Post Posted: Wed Apr 23, 2014 6:54 pm
Is there anyway to tell 100%?
Just want to make sure before I order another adaptor I can't use.
Wou l d you be able to tell if I posted a pic with the bolt hole measurements?
Post Posted: Wed Apr 23, 2014 6:56 pm
Might be easier to grab a vitara box.
Vehicle: 85 SJ413
Post Posted: Wed Apr 23, 2014 7:32 pm
Yep, if you take some measurements between the bolt holes I can check.
Post Posted: Wed Apr 23, 2014 7:40 pm
Sweet ben thanks,I'll measure it up tomorrow.
Post Posted: Wed Apr 23, 2014 8:03 pm
Also if it is a celica one,what pitman arm would you recommend?
I just remembered the ball joint is pushed into my steering arm not the pitman.
Vehicle: 85 SJ413
Post Posted: Wed Apr 23, 2014 8:06 pm
The Vitara pitman will fit and has the correct Suzuki taper for the balljoint, but is quite flat with not much drop. A Toyota Tarago pitman arm will also fit, and has similar drop to the stock Sierra pitman arm, but the taper for the balljoint is biggger, so will need a different balljoint or a tapered sleeve.
Post Posted: Wed Apr 23, 2014 8:16 pm
I'm only sitting at pretty much standard height so the flatter arm might not be so much of a problem?
Vehicle: 85 SJ413
Post Posted: Wed Apr 23, 2014 8:24 pm
That's true. The top of the balljoint stud misses the chassis by about 10mm with the Vitara pitman from memory, so you could eyeball how different that is to your current setup and make sure the drag link isn't going to be at too much of an angle.
Post Posted: Wed Apr 23, 2014 8:25 pm
I'll suss it all out tomorrow mate and let you know.
Thanks heaps for your help.
Post Posted: Thu Apr 24, 2014 7:57 am
Ok I removed some grease and lo and behold 'toyoda' is stamped on the front.
Does this narrow it down?
Vehicle: 85 SJ413
Post Posted: Thu Apr 24, 2014 10:22 am
Maybe put up a picture of the top just to be sure, but its definately looking like a Celica / Cressida box.
Users browsing this forum: No registered users and 351 guests
