It is currently Wed Oct 28, 2026 11:26 pm
Post Posted: Thu Apr 24, 2014 9:28 pm
Ok so for a first for me im going to make my own exaust. previous experience has not got me what i wanted so time to have a crack.
i have extractors, and some new 2inch pipe (i know its proberbly to big for a F10A but its what i have)
i was going to go to the wreckers and get a CAT from a commodore or falcon or something? that will be more than sufficient for a little motor, then a flex pipe, run the tube as high as i can with one muffler up over the back diff.
my question..
when i buy a muffler, (we have a exhaust warehouse localy) do they come in a range of muffleling effects? it NEEDS to be legal but id like it to have some bark! :D being a flat tray i wont notice it much inside.
will i need a hot dog to go with the mufler? or will one be enough?
Phil
Vehicle: LJ80 Stockman
Post Posted: Thu Apr 24, 2014 9:52 pm
I couldn't tell you what size my exhaust is, but my best guess is its 2" and only a muffler coming off the F10A from extractors.
Its fairly loudish inside, but its a LJ80 soft-top, i haven't heard it from a spectators point of view.
Post Posted: Fri Apr 25, 2014 6:52 am
No need for a commodore cat- they are 2.25" and super heavy and bulky. Find something smaller. They will all flow plenty for a 1.0.
Post Posted: Fri Apr 25, 2014 6:55 pm
It was more for how common they are than flow.
Any idea on mufflers?
Post Posted: Fri Apr 25, 2014 7:06 pm
Mufflers
http://redbackperformance.com.au/pdf/re ... arrels.pdf
Most cheap ones on ebay are megaflow mufflers, which will produce more noise.
I dont feel the suzuki's need to breath that much, and I would happily sacrifice some top end power for a quiet muffler.
Probably easiest and cheapest to go to the wreckers and hunt for a stock muffler in the size wanted.
Post Posted: Fri Apr 25, 2014 10:05 pm
I'm after some note tbh.. just wondering what has worked for other's!
Redback is a fairly well known brand so will be worth looking into.
Post Posted: Fri Apr 25, 2014 10:07 pm
When I first built Piggles with the 1.0 in it I ran a swift GTi rear box. Sounded fine. Finished just behind the rear axle from memory.
Steve
Post Posted: Sat Apr 26, 2014 10:22 pm
What year is the vehicle?
I reckon you should have a crack at a fiber packed stock harley muffler :D . They go for cheap as chips on ebay, are very compact and muffle quite well
Post Posted: Wed Apr 30, 2014 7:30 pm
Dont know if this helps but i had a f10a in my carry van and heres the upgrade i did ... sounded great ...
and yeah 2 inch is probably a bit overkill..
Post Posted: Wed Apr 30, 2014 8:35 pm
Intresting jr its a 92 mg410
What was the muffler?
Users browsing this forum: No registered users and 275 guests
