https://auszookers.com/forum/
auto 1.3?
https://auszookers.com/forum/viewtopic.php?f=5&t=4654
Author:  spw93_zuk [ Tue Apr 21, 2009 2:29 am ]
Post subject:  auto 1.3?
is there an auto gear box that goes on to a 1.3L zook motor??
Author:  want33s [ Tue Apr 21, 2009 1:01 pm ]
Post subject:  Re: auto 1.3?
An adapter is available to mate a (vitara)1.6 to a manual from a (sierra)1.3 so I reckon with slight modification you could use it to mate a (sierra)1.3 to a (vitara)1.6 autobox.
Jas.
Author:  tanshi [ Tue Apr 21, 2009 4:46 pm ]
if you can find one the jimny box will bolt straight up to the 1.3 block.
Author:  MUD-PIG [ Tue Apr 21, 2009 8:06 pm ]
Are you sure about that....? Does that then mean a 5speed from a Sierra would bolt to a newer 1.3 Jimny motor...?
Author:  shep [ Tue Apr 21, 2009 8:39 pm ]
as long as it is a g13 it should
Author:  tanshi [ Tue Apr 21, 2009 8:40 pm ]
i should clarify, g13bb jimny box. m13s will not
Author:  joeblow [ Tue Apr 21, 2009 11:33 pm ]
yes, but it will be a manual 'auto' as the electronics require the injection system of a g13bb in front of it.
you could adapt a TRAUMATIC behind it........................................
but i'd much rather spend my time at the pub
which is waht you will be thinking when the tri-matic packs up on the side of the road!
Author:  kenn [ Wed Apr 22, 2009 1:02 am ]
Not to mention how slow it will be ,lugging all that iron around :wink:
Author:  spw93_zuk [ Wed Apr 22, 2009 1:06 am ]
cuz autos i find easer in the bush but i thin k i might just get a new hevy duity cluch:)
Author:  kenn [ Wed Apr 22, 2009 1:15 am ]
Don't get me wrong ,i have an auto in my car and fully agree with you .I just don't like TRAUMATIC'S .
Author:  spw93_zuk [ Wed Apr 22, 2009 1:40 am ]
yer i know wat you mean but wat motor you runn
Author:  joeblow [ Wed Apr 22, 2009 1:57 am ]
for starters..............
yes, i know what you mean, but what motor do you run?
please continue.................
Author:  kenn [ Wed Apr 22, 2009 2:14 am ]
1.6Vit EFI,Aisin Warner 4speed auto.. :D
Author:  atari4x4 [ Wed Apr 22, 2009 8:10 pm ]
Jas.
there would be some serious fab work involved, the vitara has the X~fer case on the back of the gearbox & the sierra is a divorced X~fer case.
Author:  kenn [ Wed Apr 22, 2009 10:25 pm ]
Yeah, a little bit of work, I'm running a Sierra transfer with a short jack shaft and a support bearing for the output of the auto.
soon to be dual transfer. :lol:
Author:  joeblow [ Wed Apr 22, 2009 11:31 pm ]
deuling transfers?.......................................with swords?
Author:  blingdup [ Wed Apr 22, 2009 11:42 pm ]
What signal does the Jimny auto need from the injection to make it operate properly? I have a gti engine and wouldnt mind an auto behind it. What are these boxes like?
Author:  atari4x4 [ Wed Apr 22, 2009 11:48 pm ]
I challenge you to a dual or was that duel?? :?
Author:  kenn [ Thu Apr 23, 2009 11:57 am ]
Fixed !
Author:  tanshi [ Fri Apr 24, 2009 9:35 pm ]
couldnt tell you what signals it will and wont need. Im putting my jimny box behind a 1.6 baleno. I would assume that if the ECU you have for the Swift has the pin outs for and auto box these will do it.
People will tell you that they arent very strong. Incomparision to the AW4 they probably arent.
