It is currently Mon Oct 26, 2026 2:02 pm
Vehicle: hkbjk
Post Posted: Wed Jun 25, 2014 6:38 am
Since this was suggested to me in a reply to another question I had I thought I would just throw it up on its own to see if anyone has done, or has any information on moving the front diff further forward on a Jimny?
The purpose of it being to create a better approach angle while still having a front mount winch and bar set up.
The car has AC which pushes the winch mount a bit further forward.
My other option is to do a central mount winch or make a bar that mounts the winch higher which would block more air to the radiator.
I would like to know whats involved and how far forward can the front diff be moved and still keep good articulation?
Post Posted: Wed Jun 25, 2014 6:43 am
Mine is moved forward a bit. Need radius arms and tail shaft extension. If ya get radical then everything between the diff and chassis will need to move as well.
Post Posted: Wed Jun 25, 2014 7:31 am
If the diff comes forward enough to be useful you'll have issues with clearance behind the headlights.
It's a pretty major fabrication job too.
Vehicle: hkbjk
Post Posted: Sat Jun 28, 2014 2:42 pm
At this stage I might just try to move the AC unit away from the front of the radiator - any suggestions or has this been done?
Vehicle: sj51
Post Posted: Sat Jun 28, 2014 3:21 pm
Ive driven alot of trails in the wotto's very rarely has the bullbar/aproach angle been the limiting factor
Users browsing this forum: Google [Bot] and 304 guests
