It is currently Tue Oct 20, 2026 12:32 pm
Vehicle: 6.5s, gti, 31 extremes
Post Posted: Thu Apr 23, 2009 9:56 pm
anyone put the 1L transfer case into the 1.3L zook.. wanting to know wat is needed to complete the transfer
Post Posted: Thu Apr 23, 2009 10:27 pm
If your 1.3 is a NT then straight swap. If it's a WT you will have to change the flanges off your 1.3 case onto the 1lt case.
Post Posted: Fri Apr 24, 2009 12:10 am
If its a transfer without a 4x4 light what do you do ?
Can you drill the flanges
Post Posted: Fri Apr 24, 2009 12:12 am
its not a staight swap at all unless you have a 1ltr box with the 4wd switch.
To get it to fit you need to put the t/case ands of the 1ltr tailshafts on the end of your 1.3 shafts. can be done but the unis wont be as strong. I ran mine for ages untill i got some propper gears.
Users browsing this forum: No registered users and 180 guests
