It is currently Wed Oct 28, 2026 5:15 pm
Vehicle: Suzuki Sierra
Post Posted: Sun Jul 06, 2014 1:03 pm
Hey Guys,
I have a Coily and I'm half way through a transfer case swap with a switched 1lt case, I pulled out the stock t-case and removed the flanges and put them on the 1lt case. Then it was my understanding that the 1lt case should just bolt up, but it does not fit. The passenger side mount does not line up with the 1lt case and the driveshafts don't work either. The one coming from the gear box is too long, the one from the front diff is very tight and the one going to the rear diff is to extended. It looks like the driveshaft issues would be resolved by moving the t-case backwards and I'm thinking the proper mounts would achieve this? If this is the case what mounts do I need?
Thanks for the help.
Post Posted: Sun Jul 06, 2014 3:57 pm
Try this thread mate. http://auszookers.com/forum/viewtopic.p ... 4&start=30
also search for coily96 build thread as I'm pretty sure he swapped a 1 litre case in.
Post Posted: Sun Jul 06, 2014 8:51 pm
Thanks for that, so I picked up a passenger side mount today and that has the case seated well, from my readings of that ^^ thread and this one
viewtopic.php?f=5&t=45291
I think what I need is a WT jackshaft and WT front driveshaft, my plan is to undo the uni joints and replace the WT flanges with my coily ones. Can you see any reason why this would not work?
Users browsing this forum: Google [Bot] and 255 guests
