It is currently Mon Oct 26, 2026 6:17 am
Vehicle: SJ80/G16B (Zebedee), U1700L
Post Posted: Thu Jul 10, 2014 11:30 am
Greetings.
As per the title. 1994 Sierra - been my daily drive for over 5 years with no issues. Yesterday died at the lights. Fire went out but everything else still worked. Tracked it to a blown Ign fuse. Replaced it and went off again.
On the way home (exactly the same spot) it blew again. and again. and again.
Four fuses and 700 metres later I got to a Super-Cheap and bought more fuses.
Got home, cleaned up the wiring (water and oil spattered) and swapped the 15 amp for a 25 amp.
Since then no problem.
Any ideas (apart from a short which I spent all last night looking for) as to the possible culprit?
My thinking is that if it blew a 15 but not a 25 then it's probably not a short. Coil perhaps?
TIA
Nigel.
Vehicle: Sj70 tintop
Post Posted: Thu Jul 10, 2014 3:45 pm
all i know is BE CAREFUL putting in a bigger fuse, the fuse is designed to blow to protect the wiring, just chucking in a bigger fuse isnt really a good cure and risky.
look for any rub threw the harness or bad earths etc.
Post Posted: Thu Jul 10, 2014 6:11 pm
I had this problem but no idea why... Now I have a problem of the fuse melting then blowing... I know this doesn't help hahahah...
Post Posted: Thu Jul 10, 2014 6:21 pm
its a suzuki thing i reckon, my 11 jimny did that to the wiper fuse, melted the fuse, fried the main wiring harness than finally blew the fuse.
useless.
Post Posted: Thu Jul 10, 2014 7:28 pm
Yeah most likely hahaha.... If I had a random guess it'll be a few bad earth points I reckon...
Users browsing this forum: Google [Bot] and 243 guests
