It is currently Tue Oct 27, 2026 10:38 am
Vehicle: Which one?
Post Posted: Sat Jul 12, 2014 5:14 pm
So much for Suzuki's being well designed.
Installing my Dobinson kit today and managed to accidentally pinch the passenger side lower ball joint boot. I imagine it won't be long until the joint itself is flogged out, with oil slowly escaping and dirt and dust entering.
I know the ball joints themselves are not replaceable, but are there any options for me to fix this without having to completely redo the whole day's work as well as the expense of buying new arms?
Shitty day is shitty.
Post Posted: Sat Jul 12, 2014 5:18 pm
You can buy just the boot. If you can get it off rip into Repco, they have them for like $3
Vehicle: Which one?
Post Posted: Sat Jul 12, 2014 5:19 pm
Fuck. Yes.
Post Posted: Sat Jul 12, 2014 5:20 pm
Get a flat blade screwdriver and lever the boot off from the bottom.
Vehicle: LJ50V 2 stroke
Post Posted: Sat Jul 12, 2014 5:22 pm
just buy the ball joint boot. you might need to measure the ball joint where the boot seats and where the boot currently sits on the pin to get one the correct diameter
undo the ball joint slip the boot on. easy fix
Vehicle: Which one?
Is there a clip of some sort?
This thing has 10 years of shit on it. I don't want to fuck it more.
Vehicle: 85 ' Drover
Post Posted: Sat Jul 12, 2014 5:52 pm
Clean the shit off first. You don't want any dirt getting into the ball joint while you change the boot.
Post Posted: Sat Jul 12, 2014 5:57 pm
They usually have a metal ring that sits tight down around the bottom. If you can get your flat blade screwdriver underneath it they just lever off. You might need to encourage it with a hammer
Vehicle: Which one?
Post Posted: Sat Jul 12, 2014 6:02 pm
Thanks for the help, guys. I'll whip it off first thing in the morning and see if I can manage to find one on a Sunday. Failing that, I'll get it from my normal local parts dude.
Vehicle: Which one?
Post Posted: Sun Jul 13, 2014 12:11 pm
It seems this might be a bigger job than time I have in the day. Reading the FSM, it looks like I have to pull the whole hub assembly off, buy a puller of some sort for the ball joint, basically strip down the entire front suspension to get to the boot?
Someone correct me if I'm wrong.
Post Posted: Sun Jul 13, 2014 12:48 pm
Just split the ball joint with a solid hit with a hammer ;)
Vehicle: Which one?
Post Posted: Sun Jul 13, 2014 1:09 pm
I have been bashing the shit out of this thing with a fork/separator thing. It won't budge!
Vehicle: Which one?
Post Posted: Sun Jul 13, 2014 1:23 pm
Got it! The technical term for the solution is "hit fucking harder".
Post Posted: Sun Jul 13, 2014 4:43 pm
You just need a bigger hammer ;)
Vehicle: Which one?
Post Posted: Sun Jul 13, 2014 5:02 pm
Boot on and everything reassembled. I am not 100% happy with how it fits - the springs provided with the new boots aren't as tight as I'd like, but it was impossible to use the existing metal ring - but it's going to last a damn sight longer than one with a tear in it.
Users browsing this forum: Google [Bot] and 179 guests
