| 1.6 16V identification ????? https://auszookers.com/forum/viewtopic.php?f=5&t=4703 |
| Author: | want33s [ Sun Apr 26, 2009 10:11 pm ] |
| Post subject: | 1.6 16V identification ????? |
I'm in the process of rebuilding a 1.6 (big block) for my Zook. It's a 16V bottom end that I'll put a 1.3 head and (1.6)TBI on. Question is: How do I tell if it's a 92-95 or a 96-98 model engine? Jas.
| Author: | joeblow [ Mon Apr 27, 2009 1:13 am ] |
| Post subject: | Re: 1.6 16V identification ????? |
did it have steel bracing rails on the bearing caps? oh, and does the sump have a hole for what looks like a crank angle sensor in the front? if it has rails its an early job. if it hs no rails and a port on the front of the sump she is a late model job. and i hope it 1.6 8 valve injection you are using. |
| Author: | Saam [ Mon Apr 27, 2009 1:57 am ] |
yes his tbi is the 8 valve one |
| Author: | want33s [ Mon Apr 27, 2009 2:58 am ] |
joeblow wrote: did it have steel bracing rails on the bearing caps? oh, and does the sump have a hole for what looks like a crank angle sensor in the front?
if it has rails its an early job. if it hs no rails and a port on the front of the sump she is a late model job. and i hope it 1.6 8 valve injection you are using. No stud girdle and it has a hole in the front of the gasket face on the sump.... So a late model?? Yes TBI is 1.6 off an import Vitara from NZ. Thanks Joe. Jas. |
| Author: | joeblow [ Mon Apr 27, 2009 12:29 pm ] |
yep, type 2 onwards. |
| Author: | 11_evl [ Mon Apr 27, 2009 2:40 pm ] |
changing pistons, make sure you note floating pin or not. makes a difference with the 8v pistons |
